going to clean my IAC where is it located on a 04 grand prix??
sprayed a lot of throttlebody cleaner inside still running like crap could the MAF sensor be bad ?
Maybe.
Unplug it, then start the car. It might take a few attempts to get it running but if it idles smooth afterwards and runs okay, then I'd say the maf is faulty.
Your check engine light will come on because the MAF is unplugged.
ok will try tomorrow morning every morning when I start my car it revs up and down for a minute then runs normal ?
no I haven't is it hard at all ??
No. It's 2 screws and 2 nuts to take off and unplug the TB
Edit: of course that's after you remove the maf and whatever intake setup you have
thanks guys got it off now time to clean it
ok got it clean but still runs like crap I was reving it slow going to the rpm's soon as it hits 2000 rpm starts sputtering ?
did that and then the car just was putting around maybe need new plugs and wires ?
Crap it's deeper than a idling problem right?
So it stumbles through the power band or just at 2k?...fuel filter maybe
When was the last time you changed plugs/wires...
Did you scan it to see if there is any codes.
Run a can of seafoam in the tank...maybe dirty injector....start with the simple....do a close visual inspection of vac lines, wiggle spark plug wires to make sure they are on tight,cus it out
I did the plug and wires last summer but put a crap ton of miles on it when I started work and starts at 2k all the way up till the cutoff don't remember when I did the fuel filter
I will get a can of seafoam tomorrow morning and try that
Is this where the iac is located ?
The car uses the throttle body to keep the engine idling.
