Thread: IAC
Results 1 to 20 of 22
  1. #1 IAC
    May 2012
    Canada , Sarnia
    going to clean my IAC where is it located on a 04 grand prix??
  2. #2 Re: IAC
    Nov 2012
    Madison
    Canadians with 04+ GPs don't have them
  3. #3 Re: IAC
    Just clean the throttle body itself, as that is the IAC.
  4. #4 Re: IAC
    May 2012
    Canada , Sarnia
    sprayed a lot of throttlebody cleaner inside still running like crap could the MAF sensor be bad ?
  5. #5 Re: IAC
    Maybe.
    Unplug it, then start the car. It might take a few attempts to get it running but if it idles smooth afterwards and runs okay, then I'd say the maf is faulty.
    Your check engine light will come on because the MAF is unplugged.
  6. #6 Re: IAC
    May 2012
    Canada , Sarnia
    ok will try tomorrow morning every morning when I start my car it revs up and down for a minute then runs normal ?
  7. #7 Re: IAC
    Nov 2012
    Madison
    Did you actually take the TB off to clean it?....if not you might want to do that
  8. #8 Re: IAC
    May 2012
    Canada , Sarnia
    no I haven't is it hard at all ??
  9. #9 IAC
    No. It's 2 screws and 2 nuts to take off and unplug the TB
    Edit: of course that's after you remove the maf and whatever intake setup you have
    04 Comp G.
  10. #10 Re: IAC
    Nov 2012
    Madison
    Yep just like that
    Scrub it clean with some rags and TB spray
    And get some MAF spray since it will be off...but don't scrub on the MAF
  11. #11 Re: IAC
    May 2012
    Canada , Sarnia
    thanks guys got it off now time to clean it
  12. #12 Re: IAC
    May 2012
    Canada , Sarnia
    ok got it clean but still runs like crap I was reving it slow going to the rpm's soon as it hits 2000 rpm starts sputtering ?
  13. #13 Re: IAC
    Nov 2012
    Madison
    Next step is what FFDP said
  14. #14 Re: IAC
    May 2012
    Canada , Sarnia
    did that and then the car just was putting around maybe need new plugs and wires ?
  15. #15 Re: IAC
    Nov 2012
    Madison
    Crap it's deeper than a idling problem right?
    So it stumbles through the power band or just at 2k?...fuel filter maybe
    When was the last time you changed plugs/wires...
    Did you scan it to see if there is any codes.
    Run a can of seafoam in the tank...maybe dirty injector....start with the simple....do a close visual inspection of vac lines, wiggle spark plug wires to make sure they are on tight,cus it out
  16. #16 Re: IAC
    May 2012
    Canada , Sarnia
    I did the plug and wires last summer but put a crap ton of miles on it when I started work and starts at 2k all the way up till the cutoff don't remember when I did the fuel filter
  17. #17 Re: IAC
    May 2012
    Canada , Sarnia
    I will get a can of seafoam tomorrow morning and try that
  18. #18 Re: IAC
    May 2012
    Canada , Sarnia
    Is this where the iac is located ?
  19. #19 Re: IAC
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    That's your evap solenoid bro, as they said, you don't have an IAC on your car.
  20. #20 Re: IAC
    The car uses the throttle body to keep the engine idling.
