lol that was from another member, damn near same name as me though. The Guz vs The Gut. But just to make sure I'm following, heres my understanding.
-crankcase needs vaccuum for gases, so drilling out the throttle body and attaching a fitting that will let you run a line to a breather cap on the valve cover will supply fresh air.
-the vent for excess pressure is the PCV valve on the top of the plenum on the passenger side.
-putting a breather valve on the stovepipe on the top of the L26 manifold gives the crank gases a way to vent (???bypassing the PCV valve????) but does not supply fresh air to the crankcase.
now assuming i got that straight, heres my questions
-where is the crankcase gettting air from now that it needs to vent through the breather? do i need to plug something when i install the vacuum line?
-everyone keeps referring to a "metered air supply" in those threads you gentlemen have posted for me. Not sure, but I've gotten the impression that that applies more to L67 then L36?
-when i tap out the plug and put in the fitting, should i also put a fitting on the rear valve cover so i can run fresh air lines to both sides? or maybe grab another front valve cover out of the junkyard so i can screw on another breather assembly same as the front? or is just air to the front valve cover sufficient?
thanks again guys, sorry to make you break it down barney-style for me.
