Thread: Air injection valve relay
Results 1 to 2 of 2
  1. #1 Air injection valve relay
    Jan 2015
    iowa
    I have a 2007 grand prix that is throwing code po411 (secondary air incorect flow). the pump runs when you start the car so i'm pretty sure something is wrong with the valve. the schematic that i pulled off of mitchell1diy showes seperate relays for the pump and the valve. i found the relay for the pump taped to a wiring harnes down by the air filter housing but i can't find the valve relay. its my daughters car and the factory remote start wont work until i get this code cleared. will someone please help me so she will stop complaining to me about it.....lol
  2. #2 Re: Air injection valve relay
    Found some of the GM Info on it. Good stuff to check
    Fault code P0411, Secondary Air Injection System Fault
    Listed possible causes
    Circuit relay or fuse open
    Where do I find circuit relay and fuse?
    I have two fuse panels 1) beside engine belt and 2)behind kick panel at passenger front, neither said air pump.
    Check connector and wiring
    Where are wiring connectors I need to be checking?
    Air pump defective or hoses blocked
  1. Air Injection Relay connector replacement problem!
    By eleindc in forum General Grand Prix Discussion
    Last Post: 07-25-2013, 01:54 AM
  2. Air Injection Check Valve replacement
    By ajohnson2u in forum General Tech Discussion
    Last Post: 03-10-2012, 01:38 AM
  3. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  4. Where Is The Relay For The Secondary Air Injection System?
    By jarkayman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2011, 02:43 PM
