Thread: Got some questions about the top swap??
Results 1 to 5 of 5
  1. #1 Got some questions about the top swap??
    Aug 2008
    Florida
    Hey guys,
    I know i haven't been on here in forever but I've been working a **** load.
    So i got money saved up for a top swap.
    I've heard of people going to junk yards and getting the supercharger off the GTP instead of ordering it off the internet.
    I was wondering what other parts i needed as well for the swap/
  2. #2 Re: Got some questions about the top swap??
    look around first before you buy. i got a sweet deal on mine, for $600 i got everything i needed for the swap plus a cam, comp pushrods, and oe-r lifters. the junkyard might not be your best bet. you might be able to get it from people on here or clubgp.
    just for the record, you need a lot more than the blower to make it work.
  3. #3 Re: Got some questions about the top swap??
    TDCRacing
    Guest
    Blower,BBV,L67 coil bracket,L67 pullies,PCM,L67 engine harness
    To name a few
  4. #4 Re: Got some questions about the top swap??
    dont need the pcm..here is my list:
    heads
    LIM
    m90
    TB
    fuel rails
    injectors
    coil pack bracket with idler
    tensioner to go with coil pack bracket
    standoff idler
    crank pulley
    i think that is it besides all the gaskets that go in between. you dont need the pcm because you can just flash a gtp bin on it and youre good to go. the only thing that wont work is the bbv, but you then have to make it vacuum controlled instead of by the pcm, piece of cake.
  5. #5 Re: Got some questions about the top swap??
    Barksdale AFB, LA
    This sticky explains everything needed:
    http://www.grandprixforums.net/f17/t...lots-7763.html
    2009 Subaru Impreza WRX STI
  1. A ton if Questions for my upcoming top swap
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 01:36 AM
  2. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  3. DIC swap
    By chrissbee77 in forum General Tech Discussion
    Last Post: 02-26-2008, 06:02 PM
  4. Need For Gen V swap ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2008, 04:20 AM
  5. A few top swap Questions
    Last Post: 02-07-2008, 08:49 PM
