Its gon brek dwns
Its gon brek dwns
Man my wife don't work and i have a 3 month old and i can't afford a tow truck and i don't have any friends or family around i just moved to nc for work. but I'm sorry you all i even asked i just didn't know if it was normal. and i wanted to look into it, better to be safe then sorry
The vehicle doesn't need to get to 210 degrees, it only needs to be close to 195 since that's the thermostat temperature. 210 is just the temperature that the low speed fan setting is set for, and it's primarily meant for when you're not moving quick enough to generate sufficient airflow through the rad. Be happy it doesn't easily reach 210
Check all your pulley's by hand with the belt off for side-to-side play or noise when they rotate. A little movement is normal for the belt, but it shouldn't be jiggling a ton. One bad pulley will affect every other pulley.
And everyone just likes to bust your balls here, don't take it personally ;D
As someone who has recently moved, I know it is possible to be working your tail off AND be broke. Also, a woman with a three month old child already has a job... That three month old child! Cut the guy a little slack. Nobody here knows his whole story.
Rant over. Carry on.
