Thread: Recently replaced intake gaskets/tstat now the car is running much hotte, HELP!
Results 1 to 5 of 5
  1. #1 Recently replaced intake gaskets/tstat now the car is running much hotte, HELP!
    SE Level Member Blacknight02GT's Avatar
    Feb 2009
    Buffalo,NY
    SO i can't seem to figure this one out. I recently had my intake gaskets replaced, tstat, and coolant temperature sensor (not b/c they were bad but bc they were right there and might as well be replaced). Anyway, before this, the engine temp would run about 180-185 degrees F. Now, since I've gotten it back, it runs about 185-190 for a bit while driving, then it creeps up toward 210. Once, it sits idling for a bit the temperature creeps up even further past 210 to around 220-230F; but the car never overheats, the fans will come on and kick it back down to a balmy 210F. This is all just really strange to me because the car never ran anywhere near this hot before. Any ideas/suggestions? Coolant level is full, i double checked it. Tstat was replaced with stock.
    2002 Grand Prix GT (K&N + Ram Air = BEAST)
  2. #2 Re: Recently replaced intake gaskets/tstat now the car is running much hotte, HELP!
    gardner,mass
    Did you bleed the coolant? What did you use for coolant?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Recently replaced intake gaskets/tstat now the car is running much hotte, HELP!
    Feb 2009
    Buffalo,NY
    Yes, and yes I used Dexcool/ the same coolant that has always been used with this car
  4. #4 Re: Recently replaced intake gaskets/tstat now the car is running much hotte, HELP!
    Sep 2014
    Worcester, MA
    What are you using for a gauge?
  5. #5 Re: Recently replaced intake gaskets/tstat now the car is running much hotte, HELP!
    This sounds perfectly normal to me. Gauges are only rough ideas of things, they aren't perfect. Otherwise they'd be digital only. Even then.. how perfect is the sensor etc, how much tolerence is built into the T stat?
    Your fans are programmed to come on around 218F with high speed fans coming on around 228F. This explains why you see the temps you do now. As for why you didn't before... not sure.
  1. replaced intake gaskets now FOB doesnt work
    By rodburner in forum General Tech Discussion
    Last Post: 11-17-2013, 09:44 AM
  2. replaced head gaskets...issues putting back together
    By Cletz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 06:49 PM
  3. Intake Replaced, Still Running Lean
    By grandamle91 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 12:30 AM
  4. Spun bearings after mechanic replaced head gaskets, UIM and LIM
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-13-2011, 03:41 PM
  5. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
