This sounds perfectly normal to me. Gauges are only rough ideas of things, they aren't perfect. Otherwise they'd be digital only. Even then.. how perfect is the sensor etc, how much tolerence is built into the T stat?
Your fans are programmed to come on around 218F with high speed fans coming on around 228F. This explains why you see the temps you do now. As for why you didn't before... not sure.
