Thread: lower intake bolts
Results 1 to 5 of 5
  1. #1 lower intake bolts
    Nov 2014
    winston salem,nc
    So i installed my new lim gaskets etc and i forgot to put thread lock on the bolts should i pull my intake and redue it all and replace the gasketsagain and use thread lock or will it be okay?
  2. #2 Re: lower intake bolts
    Nov 2014
    winston salem,nc
    Also would it be a good idea to put Indian head gasket sealer or copper spray for a better seal? or just get it clean?
  3. #3 Re: lower intake bolts
    I would pull just the bolts one at a time and put a teflon based paste/sealer on them. Using metal gaskets, I like to use 15ft lbs of torque. The only potential that you leave yourself open for w/o a sealant/loctite on the bolts is coolant and oil seeping up the bolt threads and onto the lower intake.
  4. #4 Re: lower intake bolts
    Nov 2014
    winston salem,nc
    Alright. i need to replace lim gaskets anyways because i over torqued them and this is the last time i want to do it for awhile. so 15ft lbs for the aluminium gaskets. i done 25ft lbs because i could not find the specs anywhere and spend hours on google lol
  5. #5 Re: lower intake bolts
    There is a torque spec thread here on the forum. Although it'll say 11 or 13 based on which gaskets were available at the time.
    The plastic frame only was 11
    The plastic frame with metal inserts around bolt holes was 13
    I personally decided on 15 for the aluminums
  1. lower intake and supercharger bolts.
    By crashmydaytona in forum Wanted To Buy - Parts
    Last Post: 10-21-2014, 03:44 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  5. Lower strut mounting bolts-- where to buy?
    By lightheat in forum Brakes/Suspension/Chassis
    Last Post: 08-01-2010, 08:56 PM
