Thread: Timing is getting retarded, running out of things to try
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #1 Re: Timing is getting retarded, running out of things to try
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Replace the ****ty msd coils with stockers. MSDs are junk and could be contributing to your problem if they are failing. which they probably are. And if they aren't they will be soon enough.
    04 GTP -HAI, 1.9 rockers.
  2. #2 Re: Timing is getting retarded, running out of things to try
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I had Iceman6669 tune my 99 GTP and so far I like his work
  3. #3 Re: Timing is getting retarded, running out of things to try
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    the thing with msd's they dont even produce as much voltage as your stock ones do, and they wont last as long
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. Im sorry if this is retarded..
    By FriboRage in forum Off Topic Discussion
    Last Post: 01-25-2013, 09:44 AM
  3. Damn thiefs!!! At least they were retarded.
    By benner in forum The Rant Forum
    Last Post: 03-15-2011, 07:54 PM
  4. im retarded
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 11-20-2008, 07:42 PM
  5. Time Running Out Klms Need To Know Things
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-19-2008, 09:28 AM
