Thread: Ac clutch Help
Results 1 to 11 of 11
  1. #1 Ac clutch Help
    Sep 2014
    Indianapolis
    my ac clutch or compressor has gone out and its maybe a weird noise. at first i thought it was the belt of cousr it wasnt. so i looked closer and the pully on the clutch is kinda wiggling......... so is there a way to just take it out completely and place a pulley there so i can still have my stock belt or is there a way to get a smaller belt to work? im not buying a new compressor air dont blow out of the driver side anyway but i dont care about that
    BTW the compressor has been making noises for a while now its just worse now.
    Please help!
  2. #2 Re: Ac clutch Help
    Sep 2014
    Indianapolis
    its a 2000 Pontiac grand Prix GT 3800 series 2
  3. #3 Re: Ac clutch Help
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Yeah, you can remove it and use an A/C delete pulley which lets you keep the stock belt.
    I do believe it's actually an a/c delete pulley from a GM 2.8 v6 that people use that gets the job done if you have to order one from a parts store.
    Heres what it looks like, zzp sells them aswell http://shop.zzperformance.com/store/...AC-Delete.aspx
  4. #4 Re: Ac clutch Help
    Sep 2014
    Indianapolis
    okay thank you
  5. #5 Re: Ac clutch Help
    a member just changed the ac clutch while bolted on the car still irrc. theres a youtube vid shows how to do it and what puller you need to use. and how to set the air gap.
    looked rather easy really.
  6. #6 Re: Ac clutch Help
    Dec 2011
    Ontario,Canada
    Sure it's easy if you have the specialized a/c clutch pulling tool that he used from the shop he works at...
    OP:The link I posted above is the exact delete pulley you need.
  7. #7 Re: Ac clutch Help
    Apr 2014
    CT
    Quote Originally Posted by 231FUN View Post
    you can rent it from a/z
  8. #8 Re: Ac clutch Help
    Sep 2014
    Indianapolis
    is that the exact one i need or just an example?
  9. #9 Re: Ac clutch Help
    thats the delete pulley, its not a zzp part only, there are others out there for sale. maybe cheaper.
  10. #10 Re: Ac clutch Help
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    You could ask 02NavyBlue about the tool hes the one who changed his clutch. Might be able to rent it but idunno.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  11. #11 Re: Ac clutch Help
    Dec 2012
    Where 4T65E's were born
    My clutch was bad, causing it to drag on the hub and make noise. You could tell because there was literally no air gap between the clutch and hub, I couldn't even get an .002 feeler in there. I may have been able to re-adjust the gap and call it done and it would be okay, but the return springs on the clutch were bad. I ended up getting a used clutch in good condition for free.
    I bought this tool on amazon http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    I jacked it up, removed the RF tire and splash guard, removed the a/c compressor nut on the front (with an impact gun, otherwise a clutch holder tool is needed because it spins with the nut). Screwed the tool in and removed the press fit clutch, installation is the same except you remove the bolt in the end of the tool and use a spacer. Pretty simple really, there is just enough room to work with it still on the car, belt still installed. I also used an angle die grinder with an abrasive wheel to clean all rust off the hub and new used clutch. Setting the gap with the new one is just using the installation tool until it goes on to the right air gap, keep checking and turn it a little further til its correct. Then put the nut back on, and done. The tightness of the nut won't affect the press fit.
    Sold.
  1. 98 GTP A/C Clutch
    By maxster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2012, 05:52 AM
  2. ac clutch
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-12-2011, 05:04 PM
  3. clutch or?
    By grand prix newb in forum 2.3L Quad 4 (L4)
    Last Post: 06-15-2010, 01:23 PM
  4. ac clutch
    By gtbeach in forum General Tech Discussion
    Last Post: 03-06-2009, 11:59 PM
