Blew the coolant elbow so I replaced it, filled it up it seemed full then it gurgled and took more which is normal, I can see it about 1 and 1/2" below the neck, over the next 4 days I have come out and added about a pint and half, it gurgles the levels off at the to each time but next day it is down 1 and a 1/2" below neck no coolant in oil, no leaks on ground and no I still have not started it yet ( I am doing some other work while at it,bigger sway bar, f body brakes and stuff.) Anyway where is the coolant going so far it drank a gallon.
