Thread: Need a replacement coolant reservoir hose
Results 1 to 17 of 17
  1. #1 Need a replacement coolant reservoir hose
    May 2013
    Ann Arbor, MI
    I really just want to buy this hose and replace it myself, but I can't seem to find THIS particular hose. Has anyone else ever been able to find this part new?? The nearest pick pull I could go to is like an hour away. -_-
  2. #2 Re: Need a replacement coolant reservoir hose
    St. Louis
    Couldn't you get just a couple feet of fuel line and use that? Not sure it needs to be the molded hose as long as you don't kink it. Check Rock Auto and GMpartsdirect if all else fails.
  3. #3 Re: Need a replacement coolant reservoir hose
    Aug 2013
    arlington, tx
    Or you could check your local stealership. Probably wouldn't be much.
  4. #4 Re: Need a replacement coolant reservoir hose
    parts stores sell un reinforced hose that will work for that. not molded but will flex
  5. #5 Re: Need a replacement coolant reservoir hose
    Aug 2013
    arlington, tx
    Scotty, did you change your username to sallydoggs?? Hahaha
  6. #6 Re: Need a replacement coolant reservoir hose
    no, you know how the name game goes here. i got tagged good again....
  7. #7 Re: Need a replacement coolant reservoir hose
    Aug 2013
    arlington, tx
    Hahaha. Epic. Has a nice ring to it tho...
  8. #8 Re: Need a replacement coolant reservoir hose
    at least it dont say fordlovin lol like someone else...........ha ha
  9. #9 Re: Need a replacement coolant reservoir hose
    Aug 2013
    arlington, tx
    True...
  10. #10 Re: Need a replacement coolant reservoir hose
    Feb 2010
    TN
    Junk Yard is your friend for little wierd things
  11. #11 Re: Need a replacement coolant reservoir hose
    May 2013
    Ann Arbor, MI
    Quote Originally Posted by jlee5283 View Post
    Thanks guys! I did end up finding it here on RockAuto.com
    https://www.rockauto.com/catalog/x,c...2B3.8L%2BV6,ck
    I'm thinking it's a lot cheaper than I even expected! LOL
    Well apparently its not as cheap as I thought...cuz it's sold in a pack of 50 for $33 lol. Guess I'll be looking around at the junkyards this weekend!
  12. #12 Re: Need a replacement coolant reservoir hose
    what broke on your hose? or is it missing?
    my cap took a dump and cracked, so i cut the tube off the cap put it between the two hoses, the one in the tank and the other to the rad cap, then sealed it with a shrink tube, stuck the tube int he tank under the coolant line, cut a v in the cap so the line fit into the tank. no leaks any more now.
    you can see the edge of the shrink tube at the edge of the cap. so you can cut and splice it id its broken or pinched and leaking.
  13. #13 Re: Need a replacement coolant reservoir hose
    May 2013
    Ann Arbor, MI
    Quote Originally Posted by Sallydoggs View Post
    That sounds like a good idea!
  14. #14 Re: Need a replacement coolant reservoir hose
    that stuffs cheap too. maybe a buck a foot or so.
  15. #15 Re: Need a replacement coolant reservoir hose
    May 2013
    Ann Arbor, MI
    My hose has 2 fairly big holes in it, so I need to replace it. I would just cut the hose down but I believe it'd be too short if I did. I have read it wrong but I don't think that method would help me out, or would it?
  16. #16 Re: Need a replacement coolant reservoir hose
    it should work. the splice trick. you just need a tube of some sort that fits in the tube ends snugly. theres no pressure in that line, it just takes coolant back and fourth to the tank.
    metal tube maybe easier to find. i had the bright idea to use the tube in the cap cause it was already cracked on the in let side. aka junk lol
  17. #17 Re: Need a replacement coolant reservoir hose
    May 2013
    Ann Arbor, MI
    riiiight okay! I get what you're saying now! Thanks! ^_^
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Coolant Hose Replacement
    By MattF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2013, 10:41 AM
  3. Coolant reservoir
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2013, 07:41 AM
  4. Coolant reservoir
    By TheManInBlack in forum Shops and Community Heroes
    Last Post: 12-31-2011, 02:50 PM
  5. Coolant Reservoir Tube?
    By Pagss in forum General Tech Discussion
    Last Post: 10-19-2010, 01:49 PM
