Thread: found my issue
Results 1 to 20 of 21
  1. #1 found my issue
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    well i pulled the engine on the 98 removed the intake, found that the kid and his father when they did the lower intake gasket they used roloc on the manifold and the heads... damage was already done.... oh well.... i have a 99000 mile engine that im installing in the car.
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  2. #2 Re: found my issue
    What issue were you having?
  3. #3 Re: found my issue
    hangover park IL
    imma guess a rod knock... or a leaky as **** LIM gasket
    those 3m pads will easily put .010+ deep grooves in the LIM surfaces rofl
    ~James~ Psychotic Gearhead
  4. #4 Re: found my issue
    I dunno what you guys are using. I use the brown ones, don't go animal on it and works great. I also keep the material out of the engine.
  5. #5 Re: found my issue
    hangover park IL
    , your litterally adding MILLIONS of leak paths....the RA for a dynamic Oring gasket is very low and i dont think even the blue/red "polishing" discs come close to it....
    plus there's that whole TSB from EVERY major manufacturer to not use the roloc discs on internal engine components as the aluminum oxide particles end up on everything...including your hair/arms
    i prefer to use a box of single edge razor blades
  6. #6 Re: found my issue
    I knew all that... lol
    I'm a rebel. Not quite a 700whp, or twin engine car rebel...but a roloc rebel!
  7. #7 Re: found my issue
    hangover park IL
    i hope a roloc wheel spins off and hits ya in the pecker
  8. #8 Re: found my issue
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Quote Originally Posted by Turbocharged400sbc View Post
    ^ I lol'd at that xD
  9. #9 Re: found my issue
    I'm still lol'ing at that...
    Cause that roloc is gonna hurt a lot less than whatever explodes and hits him from a performance build breakage.....
    ~ The Roloc Rebel ~
  10. #10 Re: found my issue
    hangover park IL
    those only hit the owners wallets hahahaha
  11. #11 Re: found my issue
    Feb 2009
    flintnasty MI
    I helped a buddy put together a 3800 and he insisted on roloc'in everything. Milkshake rodknock 100 miles later.
  12. #12 Re: found my issue
    So what about the plastic discs that have all the little bristles? Ive always used white or blue plastic discs and nver had issues.
  13. #13 Re: found my issue
    hangover park IL
    FOR ANYONE THAT READS THIS:
    the surface can be perfectly clean and smooth while still having "staining" e.g. you will still see what looks like gasket material/gasket outlines.
    THIS IS FINE, the pores of the metal have filled in with material, carbon, graphite, etc. this staining is fine and even good in some ways (if reassembling with same components you not have good casting/core shift idea's of all the parts ad what ports might need adjusting)
    BUY a 100 pack of blades, dont buy cheapo's and you still wont blow over 14$ and a holder, clean large flat area's first, scraping and wiping on a towel. then move to the bolt hole area's as the blades get nicked by the burrs, change the blades like you just dont give a **** and youll be fine. to note the graphite headgaskets like to leave graphite in the poores but material still on the surface can blend in...look for the reflection of a light across the surfaces at a steep angle and youll see the dull area's where you missed the graphite...the area's youve cleaned and wiped with a rag (SPRAY THE RAG/TOWEL WITH THE BRAKE CLEANER) will look like glass
    this allows you the finesse of removing debris, carefully, and AWAY from the intake ports/etc, while the valley just has rags in it to catch what you miss.
    the front/rear cover gaskets and the neck gaskets suck ass but clean blades and a carefull angle will let you slice through em, dont just push, move at an angle to cutting edge.
    quick tip, if you flip the blade each time you use it on those PITA paper gaskets (one slice/saw stroke), flip it over and the fine edge burrs will make the next pass perfect, then fip again.
    do one without flipping and do it with flipping the blade...and tell me if im nuts
    i aint
    ll i am, but i aint
    bill better coppy this **** somewhere
  14. #14 Re: found my issue
    hangover park IL
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    still has aluminum oxide in em, in ways they are wores as they tend to leave a groove as someone "cleans" a stained area
    i remember one TSB actually listed how much material the discs can remove in less than a tenth of a second....and they stated rotary abrasive devices should never be used on aluminum gasket surfaces, only iron was tough enough. lol
    a good tech who masks off everything and is extremely carefull is probably quite lucky, but anything thats missed is dragged through the pump before the filter MAYBE catches it.
    i have a front cover from a roloc/rtv engine that i show people ...even a brand new pump scroll has a crapload of play around it, nevermind that the oil passage is about 3/16" dia where the front cover rtv job nearly blocked off the oil passage.
    far better sealant choices for that such as permatex aviator sealer, a non hardening sealer that congeals to itself but actually soaks into the paper fibers. plus its thin tar/brush is easy to apply even if yer fingers get sticky
  15. #15 Re: found my issue
    http://www.handymanlyness.com/archiv...d_99_Jimmy.jpg
    So these are a no go? never had a problem with them just wondering if others use these or why not to?
  16. #16 Re: found my issue
    hangover park IL
    i still use mine but its on outside surfaces and with carefull masking if the components are just being R&R'd
    shove towel balls in the exhaust ports, clean rust off iron exhaust flanges, gussy it up, that kinda bs...
    maybe on a wp gasket for aquick repair job, the problem is that while your grinding away that stubborn piece of gasket, those discs are grinding away alot of the aluminum/material on either side.
    besides, a little practice with a razor blade and a cheap holder and youll wonder why the **** you ever used roloc discs.
    my green/yellow plastic bristle discs are probably close to 15 years old now....dont use em much unless im completly rebuilding something and can clean thouroughly with my several buckets/bins of kerosene and cans of brake cleaner
  17. #17 Re: found my issue
    hangover park IL
    oh and dont throw away the old dinged up/nicked blades, they work great to scrape thicker rust off the iron block/heads (acc bolt hole area's, PS mounting boss, etc
  18. #18 Re: found my issue
    hangover park IL
    cigarette butts are perfect masking pieces for bolt holes, 8mm they fit perfectly, 10mm holes you can fold in half or shove two next to each other.
    that way your not cussing at your self upon reassembly cause the bolts will screw in by finger like that one sloot you played stinky fingers with under the bleachers back in HS
  19. #19 Re: found my issue
    Cambridge, Ontario Canada
    Done the LIM job 3 times with that Roloc yellow wheel, perfect everytime with a little care.
    2005 E55 - stock
  20. #20 Re: found my issue
    FIREFIGHTER/AEMT
    Dec 2013
    yes it was a rod knock. i did talk to the people i bought the car from and he confirmed what they did. oh well i will at least have a decent engine going in
    it comes from a 99 lesabre or park avenue. has 100k on it swapping all the parts this week and hopefully installing this weekend
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Found the issue with my transmission. *UPDATE 8/11/13*
    By Silver2kgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-12-2013, 06:53 AM
  3. Found my ABS/Trac off light issue...
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2010, 05:52 PM
  4. Got this issue please!Found problem!
    By GTP4 in forum PCM Tuning
    Last Post: 02-24-2009, 09:35 AM
  5. Found This Joke. Also Found It Amusing.
    Last Post: 12-05-2008, 04:25 AM
