Thread: Found the issue with my transmission. *UPDATE 8/11/13*
Results 1 to 20 of 21
  1. #1 Found the issue with my transmission. *UPDATE 8/11/13*
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Well as most of you know something broke in my trans off the line at Atco last month. IT was either the TC which was giving me issues for a while before Atco or the 300M input shaft.
    Dropped the trans today and there is was ......................a broken 300M IS.
    I was very surprised that it was the IS. I really thought it was the TC for which I bought a new Precision TC from Dave at TEP. Better to have the best TC anyways. As mentioned, the TC was giving me issues. Might take it to Pro Torque and have them open the TC up to take a look.
    This saturday I'm gonna open the trans and take a look around. Fluid was still nice and red. Little metal which probably from clutches and TC issues. Going to send Dave the Valve body to examine an replace all solenoids.
    Here is a vid of the run I broke.
    http://www.nymcgp.com/members/silver...co%20Break.wmv
    Here's a pic of the IS
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  2. #2 Re: Found the issue with my transmission.
    Jb weld can fix that.
  3. #3 Re: Found the issue with my transmission.
    i think i larger O ring could seal that up lol
    jokes a side, that blows.
  4. #4 Re: Found the issue with my transmission.
    Broke a 300m like a bauce
  5. #5 Re: Found the issue with my transmission.
    Feb 2008
    NY
    JB weld fixes anything. LOL
    This actually is my second IS I broke. Broke one back in 2006
  6. #6 Re: Found the issue with my transmission.
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    GMR IS or go home
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  7. #7 Re: Found the issue with my transmission.
    Feb 2008
    NY
    Quote Originally Posted by TEK310 View Post
    GMR IS or go home
    Haven't seen one available.
  8. #8 Re: Found the issue with my transmission.
    dont greg have like 2 of them? he is the new GMR badass dont ya know lol
  9. #9 Re: Found the issue with my transmission.
    its a zzp shaft, but heres the link http://www.grandprixforums.net/2-93-...ble-79353.html
  10. #10 Re: Found the issue with my transmission.
    Intense had one
  11. #11 Re: Found the issue with my transmission.
    Feb 2008
    NY
    I talk to Greg almost everyday. I'm most likely taking his 300M IS and having seals replaced
    INTENSE does sell a 1200HP IS
    http://intense-racing.com/Merchant2/...ry_Code=3800_T
  12. #12 Re: Found the issue with my transmission.
    Apr 2011
    Vassar, Mi
    Ive got brand new dynotech 300M's for sale cheap if you want to try one of them?
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  13. #13 Re: Found the issue with my transmission.
    Feb 2008
    NY
    New 300M IS in on the way. Ordered some other stock pars to replace while car is apart. LOL
    New Hayden Trans cooler has been installed. Power washed aluminum subframe. Fixed bad ABS wiring. It's amazing how much suff you can do when a car is apart.
  14. #14 Re: Found the issue with my transmission.
    It sure is..
    Good job on the shaft.. that's not an easy feat.
  15. #15 Re: Found the issue with my transmission.
    GT Level Member ls1camino's Avatar
    Laurel, MD
    I'm impressed.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  16. #16 Re: Found the issue with my transmission.
    Feb 2008
    NY
    Update - 7/22/13
    While I was away on vacation I sent the whole Valve Body unit to Dave at TEP to check out. Last thing I want is to put trans back in just to have to take out again.
    Dave is an outstanding guy and great to deal with.
    Here is what he found and is fixing and upgrading.
    - The pump appeared to have some scoring like it was started dry on fluid at one point. Needs to be rebuild and replace parts
    - Since I'm turbo, upgrade the valve body with a few newer parts. Two valves changed for any build in the 375+whp range now that give higher line pressure and a great addition to keep clutches alive on high powered builds.
    - New valve body spacer plate
    - PCS Solenoid
    - TCC Solenoid
  17. #17 Re: Found the issue with my transmission. *UPDATE 7/22/13*
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Bet your glad you sent in you valve body to Dave
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  18. #18 Re: Found the issue with my transmission. *UPDATE 7/22/13*
    Feb 2008
    NY
    Quote Originally Posted by gmr badass View Post
    bet your glad you sent in you valve body to dave
    hell yeah!!! Lol
  19. #19 Re: Found the issue with my transmission. *UPDATE 7/22/13*
    Good call for sure.
  20. #20 Re: Found the issue with my transmission. *UPDATE 8/11/13*
    Feb 2008
    NY
    Update - 8/11/13
    Trans and GP was put back together a few days ago. Drove her then and today. Trans and car feels GREAT. Trans shifts so good. No more shutter. The shutter was either a bad TC which most feel it was or the problem with the VB. Either way, I'm happy.
    Will be doing a track rental in Oct.
    With the new VB fixes and upgrades and with the bigger trans cooler now, the trans run much cooler.
  1. Transmission issue
    By BigRam2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2013, 06:06 PM
  2. Transmission Issue
    By ao482 in forum Introductions/Noob Questions
    Last Post: 04-09-2013, 07:02 AM
  3. Transmission issue??
    By xsvtank in forum General Tech Discussion
    Last Post: 11-11-2010, 09:29 PM
  4. Found my ABS/Trac off light issue...
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2010, 05:52 PM
  5. Got this issue please!Found problem!
    By GTP4 in forum PCM Tuning
    Last Post: 02-24-2009, 09:35 AM
