Thread: Engine swap???
Results 1 to 20 of 35
  1. #1 Engine swap???
    Jul 2014
    I have an 04 grand prix that has developed a horrible knock after an oil change and have come to the conclusion I need to another engine in a bad way. Well I found an engine and it happens to be a 97 camaro. Question is will it work?
  2. #2 Re: Engine swap???
    Yeah it will, just swap your entire top end over. And most of the stuff on the drive belt system as they are newer.
  3. #3 Re: Engine swap???
    Jul 2014
    Thanks for the reply. This is my first swap so entire top end? Like intake manifold fuel rails and such?
  4. #4 Re: Engine swap???
    yes swap that over. the camaro intake wont work.
    unless your going turbo lol
  5. #5 Re: Engine swap???
    Yeah, the block is the same. So you just need to swap you lower intake, upper intake, fuel rail over and do new gaskets.
    You also need to swap your oil pan/pick up tube aswell. Basically re-seal the motor before install.
  6. #6 Re: Engine swap???
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    ...and your exhaust manifolds
  7. #7 Re: Engine swap???
    Jul 2014
    Alright thank you guys
  8. #8 Re: Engine swap???
    Jul 2014
    Will the heads from the camaro engine work
  9. #9 Re: Engine swap???
    if your engine is N/A they will.
  10. #10 Re: Engine swap???
    Jul 2014
    What's n/a sorry never done a swap
  11. #11 Re: Engine swap???
    naturally aspirated and yes the heads will work.
  12. #12 Re: Engine swap???
    Jul 2014
    Alright well it's looking more and more like the engine I had lined up is gonna fall through... with that said thinking about going super charged. Besides the engine would I need the ecm and pcm as well?
  13. #13 Re: Engine swap???
    you would need your pcm tuned for a top swap or a s/c engine. depending what way you go.
  14. #14 Re: Engine swap???
    Jul 2014
    So I could keep the existing electronics just need it tuned? Even if it's a factory charged 3.8?
  15. #15 Re: Engine swap???
    and a few small wire harness changes, yes, find and read the top swap thread.
  16. #16 Re: Engine swap???
    Jul 2014
    Alright thank you I need to do something asap as the car it's my only one and Idk how much longer I have before it throws a rod so the responses and advice are very much appreciated
  17. #17 Re: Engine swap???
    the n/a 3800 should be rather abundant in local junk yards and such. they are rather cheap too. like 300 to 400 for a good used one.
    they are in more then camaros regals or GP's. newer buick cars have the 3800 too.
    try carpart.com too
  18. #18 Re: Engine swap???
    Jul 2014
    I been searching around I had an engine I know runs lined up but it appears to be falling thru so now I'm scrambling to figure something out. The localish pull a part has a couple that fit my very tight budget. Just have reservations about junk yard engines lol
  19. #19 Re: Engine swap???
    you can do some tests to make sure its good. check the oil, make sure its just oil, and so what clean smeelin. take a valve cover off, if the rockers are nice and clean thats a winner.
    then if you want to get crazy you can bring in a battery and jumper cables, (to jump the starter motor) and do a compression test before pulling it.
  20. #20 Re: Engine swap???
    Jul 2014
    Gonna screen shot this reply very helpful cuz I wouldn't have an idea on where to start in checking a junk yard engine thank you
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
