Got some weird stuff going on.....I got a 01 gt with a 3.8l in it.motor has 135000 on it...it all started about a month ago. first the car idles at about 1500rpm then i would be driving and the car would just shut down. It wouldnt die just go to an idle unless you touched the gas. Then it would die...and would not start for a good 30min. Got my scanner out and it pulled up p0101 and p0104. Basically MAF...when it shut down if i erased the code it would start right up. I replace the MAF with a ac delco and still the same problem. Doing some research i heard of the plentum(my spelling is bad) could be warpped or crack....got a new one and while i had it that far apart i did the intake gasket to. Still no help except ran smoother and a little better mpg. Changed the MAP sensor, crank sensor, IAC sensor, and TPS sensor..Fuel pressure is 51 with the key on and 45 while running..Did a smoke test and have not found any vacuum leaks. Found the car had a aftermarket remote start system on it so i removed that and repaired all the wires. Still idles at 1500 or so and now it only shuts down first thing in the morning after driving for about 5 miles. It pulls the p0101 code and i erase it and it is fine all day after that. Tired of driving with my scanner plugged in.....i am at a loss...hopefully someone can help
