Thread: Idle / RPM issue ** Videos ** - Need Help
Results 1 to 11 of 11
  1. #1 Idle / RPM issue ** Videos ** - Need Help
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I'm having an issue with my RPM's. Here's a rundown of what I did and is happening.
    I just recently changed from an LS1 TB to a Accufab Ported TB. The reason for this is the LS1 was messing up my IAC's. At least that is what I thought.
    After I installed the ported TB, my IAC's were still messed up. I found out that the wiring for the IAC was bad so I replaced the connector and wires. Being that a wire was bad, that actually might have been the problem instead of the LS1 TB.
    Anyway with the Accufab TB installed now and IAC working good. My RPM's hang high then drop after I hit the throttle. Weither if I'm in park or driving. At idle I'm at 900-1000. After I hit the throttle the RPM's go up then instead of going back down to 900 it would hang around 1300 then drop down. This is especially annoying while driving.
    My IAC is at 47 at idle. My TPS is .5 v at idle and 4.2v at WOT.
    I don't have any vac leaks because I had a smoke test done. This is driving me crazy. I'm very tempted to put back the LS1 since the IAC wiring was bad to begin with. I want to get this RPM issue figured out first. I can't/don't see why this is happening.
    Here are a couple of vids. Sorry if they are on the big side. They are in HD and didn't have time to resize.
    Any help and/or input would be great.
    http://www.nymcgp.com/members/silver...leProblem1.mp4
    http://www.nymcgp.com/members/silver...leProblem2.mp4
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
    Ohio
    The iac and tps values look good, do you think it could be how you have the vacuum lines routed?
    Are you using a vac block?
  3. #3 Re: Idle / RPM issue ** Videos ** - Need Help
    GT Level Member RideWithPride's Avatar
    Oct 2011
    might be a warn flexplate having trouble catching the teeth but honestly thats random ass guess
    Ohio
    What cam do you have sal?
  5. #5 Re: Idle / RPM issue ** Videos ** - Need Help
    Feb 2008
    NY
    I didn't change the routing of my vac lines. I do not have a vac block.
    All I did was swap out the TB's
    I have a stg turbo cam and I just put a meziere flexplate on.
    Ohio
    I'd put the LS1 tb back on..
    I'm really stumped on this one.
  7. #7 Re: Idle / RPM issue ** Videos ** - Need Help
    Feb 2008
    NY
    I'm stumped too.
  8. #8 Re: Idle / RPM issue ** Videos ** - Need Help
    Quote Originally Posted by RideWithPride View Post
    Catching teeth on what?
  9. #9 Re: Idle / RPM issue ** Videos ** - Need Help
    Oct 2011
    haha im gonna look like a fool but where the gear connect to the flywheel, which in itself the flywheel is a gear which is mainly a circle with teeth on it or calculated jagged edges, if one becomes worn or chipped is could cause the flywheel to move more freely since it would be skipping over a tooth or edge.
    This being said i have never acctually seen/heard about this happening to a car i just grew up with bikes my whole life and seen stuff like that
  10. #10 Re: Idle / RPM issue ** Videos ** - Need Help
    I'm not following what you're saying. The flywheel is attached to the tc and the motor.
  11. #11 Re: Idle / RPM issue ** Videos ** - Need Help
    Feb 2008
    NY
    Update
    Just put back the LS1 TB and still have the same issue. This is driving me nuts.
  1. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  2. Idle issue
    By CASconce in forum General Tech Discussion
    Last Post: 01-16-2012, 08:20 PM
  3. Idle issue
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 10-20-2011, 06:23 AM
  4. 1995 idle issue
    By TRAV1S in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-04-2011, 01:43 PM
  5. unique idle issue
    By 02bluegtss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2010, 12:36 PM
