Planning to topswap my 2000 L36, but do I have to run L67 heads? Can I just stay with the stock L36 heads and port them a bit?
Yes and no...top swap requires SC heads and stuff...SSM90 kit doesn't require the need for swapping heads.
Well I bought the LIM and S/C with throttle body and rails, but I still need the heads, FPR, PCM, injectors, and gaskets correct? What's the main difference between the L36 and L67 heads?
The L67 heads have ports for the fuel injectors whereas the injector ports are in the LIM for the L36.
l67/32 heards have the injector holes in the heads, not the lim like a n/a lim/
the fpr is on the fuel rails, so you got that covered.
you will need the rest of the pulley idlers, tensioner, and balancer too.
Ohhhh ok. Well that blows, looks like S/C will wait until my next paycheck lol.
I planned on going to Wrench N Go and grabbing the rest of the stuff I need, but now I can't afford it thanks to great news from Sven. :P
Yeah, I'll need the alternator bracket, and ICM bracket as well?
Oh. Ok then, that helps lol.
And don't forget a way to tune it or a pcm
