Thread: Car chugging over 4500 rpm
Results 1 to 14 of 14
  1. #1 Car chugging over 4500 rpm
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    My buddy has a 2001 monte carlo. When you floor it it seems to be lacking power over 4500rpm and at times, chugs. He said at one point the check engine light was flashing. I scanned it and it threw code p0301.
    Any ideas as to what the problem could be?
    Sent from my HTC One using Tapatalk
  2. #2 Car chugging over 4500 rpm
    Cylinder 1 misfire.... So he probably needs to fix that and/or do a tune up.
    http://www.obd-codes.com/p0301
    Send him the link and have at it
    04 Comp G.
  3. #3 Re: Car chugging over 4500 rpm
    May 2011
    What can he do to fix it, coil packs, spark plugs and wires?
  4. #4 Car chugging over 4500 rpm
    Sounds like he needs a tune up.. So start there plugs, wires, fuel filter etc. Start there. Without really nothing what maintenance has been done and how long ago.. Tell your friend to start there.
    04 Comp G.
  5. #5 Car chugging over 4500 rpm
    Aug 2013
    McDonald PA
    Jeez red tune lol just bustin ya
  6. #6 Re: Car chugging over 4500 rpm
    SE Level Member bicycles01's Avatar
    Apr 2014
    Could be a clogged cat
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Using Tapatalk
  7. #7 Re: Car chugging over 4500 rpm
    May 2011
    It just passed emissions test, would a clogged cat not fail? It has 74,000 kms, 45,000miles. Could just be at the age where everything is going to need replaced/tuned up i guess.
  8. #8 Re: Car chugging over 4500 rpm
    Apr 2014
    If its clogged up its not letting any emissions out lol had the same problem with my 01 same symptoms changed plugs , wires, fuel filter everything I could think of it would run and idle fine until I put it under power and it about died on me . Had my dealer test it and they said the cat was clogged , changed it out and she runs like dream now just something to check just incase O and mine had 60000 when this happened
    Using Tapatalk
  9. #9 Re: Car chugging over 4500 rpm
    May 2011
    Alright, I'll definitely keep that in mind, were going to try the spark plugs and wires tomorrow to see what happens. I drove it and it didnt chug, just felt like it was missing something up top, could also be that my car is supercharged lol so my perception of lack of power is distorted.
  10. #10 Re: Car chugging over 4500 rpm
    Apr 2014
    Hope you figure it out
    Using Tapatalk
  11. #11 Re: Car chugging over 4500 rpm
    May 2011
    I'll keep this thread updated.
  12. #12 Re: Car chugging over 4500 rpm
    May 2011
    It also starts kind of rough and shakes at idle, im thinking the spark plugs/wires will do the trick.
  13. #13 Re: Car chugging over 4500 rpm
    May 2011
    Are NGK TR55 GP ok plugs for an N/A car?
  14. #14 Re: Car chugging over 4500 rpm
    Id stick to ac delco iridium plugs
    04 Comp G.
  1. FS: 1998 Regal GS 73,xxx miles $4500
    By chevyy1212 in forum For Sale - Vehicles
    Last Post: 06-16-2012, 09:04 AM
  2. 197k, $4500, 04 comp g.. is it worth it?
    By vicious in forum General Tech Discussion
    Last Post: 08-10-2010, 09:55 PM
