Hello all.
I have an 05gp. Last week she starting running real rough driving on the highway, rpm fluctuation, temp gauge going crazy, intermittent power and terrible gas mileage. (I didnt pick up on the temp gauge til later) my first suspect was tranny related like the tcc or something but applying the brake slightly didnt affect anything. Rpms were still erratic.
When i discovered the wacky temp readings i changed the therm. I had planned to do so anyway because I had the therm code p0128 i think. After a few rides watching live data and trying to figure things out i got a p0118 and the temp readings were fluctuating between -38 to 192. So i changed the sensor and checked all wiring for continuity. After being satisfied with those readings i thought i was good. Put her back together and it happened again. I changed out harness etc. when i start readings look good. If i put it in gear it will drop off to -38 again and maybe come back up or fluctuate or not come back up at all. I'm confident the new ect sensor is fine. I chEcked resistance as the engine warms and it seems to be accurate. I also checked proper voltage coming from ECM and continuity from the sensor to ECM.
I've also flushed and bled system and clean throttle body and maf sensor on fairly regular intervals. I dont know what else to check. Any ideas? Could another sensor circuit cause problems with temp readings? Could it be the ECM? I'm lost. Any help would be appreciated.
