make sure the plug wires are on right. then check over the icm harness make sure its ground is tight and still connected.
then you can swap the coils around to see if the misfire follows the coil swap.
the injector, check the wires to it was well. and you can also pop the fuel rail off and swap the injectors around to see if that code follows the swap as well.
Everything has been replaced with new plugs, wires, injector and coil pack.
