Thread: Threw belt
Results 1 to 14 of 14
  1. #1 Threw belt
    Feb 2010
    TN
    Belt is in perfect shape, but it just flew off the engine, antifreeze all over but can't see from where, I am guessing water pump and tensioner and I shold be ok? Never saw one come off intact they always had tears trying to think why it slipped off like that, running hot as I pulled over the belt was off just hanging there
  2. #2 Re: Threw belt
    Check pullies, see if one is locked up.
  3. #3 Re: Threw belt
    Aug 2011
    'Merica
    I had a belt jump off once. The tensioner went bad. As for the coolant, might be a bad water pump.
  4. #4 Re: Threw belt
    Oct 2011
    Toledo, OH
    Might have nothing to do with the water pump. Check the tensioner. When the belt came off, the antifreeze might have just boiled over from lack of a water pump.
    7"
  5. #5 Re: Threw belt
    Enfield, CT
    check hoses maybe the belt flew into a hose and slashed it
  6. #6 Re: Threw belt
    St. Louis
    Wonder if a coolant elbow let go and got the belt wet enough to slip off as well.
  7. #7 Re: Threw belt
    Feb 2010
    TN
    All good ideas I will start working on it saturday or sunday coolant elbows are originals 337,000 miles
  8. #8 Re: Threw belt
    St. Louis
    Since your car is a 97, I hope the LIM gaskets have been done at some point.
  9. #9 Re: Threw belt
    Pennsylvania, USA
    Oh god, 337,000 miles on the original elbows?! I'm surprised they lasted that long, get some new ones. I'm thinking the belt may have struck an elbow when it flew off and caused a leak.
    When I replaced mine at about 80,000 the old ones fell apart in my hands.
  10. #10 Re: Threw belt
    Mar 2012
    NC
    97 only has one elbow...the other is part of the alternator bracket...
  11. #11 Re: Threw belt
    Sooo Logan, read up on the how to change coolant elbows so you don't break your timing cover.
  12. #12 Re: Threw belt
    Feb 2010
    TN
    Read that bill and I am glad I did I would have butsed that sucker in no tme LOL so based on what seven said and whatv scottys told me once what I am guessing that elbow that is part of the alt bracket does not get changed correct
  13. #13 Re: Threw belt
    correct, its part of the alt bracket, you take the new O ring off the new unused elbow, put it on the cast elbow and your set.
  14. #14 Re: Threw belt
    Yeah..it is just like they say.
  1. Threw my belt for no reason?
    By rmbtds in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-01-2013, 11:30 AM
  2. i think i threw a rod and or rod bearing.
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2013, 08:02 PM
  3. Threw crankshaft sensor
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-06-2011, 02:29 PM
  4. Video I threw together
    Last Post: 01-31-2010, 01:03 PM
  5. Threw a code!
    By TFBuckeye in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 06:06 PM
