Awesome, thanks. On a side note, is the balance shaft/bearings a common wear part? this new engine has a pretty nasty rattle when cold, and using a stethoscope, it seems to be coming from behind the water pump, exactly where the balance shaft is located. I can't isolate it to any particular cylinder, and it's more pronounced by the front/back center of the engine behind/slightly above the camshaft. Just did an oil change and nothing came out but oil, so I'm thankful for that, but is it something I should be concerned with?
