Good afternoon all! So I have been playing around with for a while but I think we need just a minute of background info:
Me: I am an ok mechanic, and a CNC Instructor for Lincoln Tech...I have access to machine whatever my heart desires, and if I can't put it together the auto mechanic side of the school can give me a hand.
My car: 99 Grand Prix with 151,000 miles. Repairs in the last year or so include: new fuel pump, fuel filter, tranny filter, map sensor, PVC valve, 180 thermostat, battery, spark plugs, spark plug wires, ignition module, coil pack (just one for now), lower radiator hose, other odds and ends I can't think of right now...biggest issue currently is leaking oil on to the manifolds...common in our cars, and the reason for this build...why replace when you can improve?
The goal: every project should have a goal and mines roughly 240 hp still N/A at the crank
So without further adieu here is the current plan:
-L26 heads machine port and polished
-L26 Upper and Lower Intake (to eliminate the plastic one) also machine port and polished as well as bore matched to an L67 throttle body
-Custom throttle body spacer to mount the L67 throttle body to the L26 Intake
-L36 Throttle body machine bored for more air flow
-90# Springs
-Rocker upgrade (looking at ZZP ER Rockers but would prefer to pull some higher ratio ones off another engine)
-ZZP front PLOG and down pipe
-custom aluminum version of the HV3
-CAI
what else can or should I do?
