Thread: Help! Lifters or worse?
Results 1 to 20 of 38
  1. #1 Help! Lifters or worse?
    Jun 2013
    North Dakota
    So after a series of massive gasket failures I went through and changed them all, now I've for this horrible knocking/ticking noise going on. I've been reading up on which one it could be but I'm not sure. Can anyone shed some light? Lifters or rod bearing? Or something else..Sound best heard towards the end of video, and I'm fully aware about the uninstalled dog bones.
    http://m.youtube.com/watch?v=zMxKRUp...e_gdata_player
  2. #2 Help! Lifters or worse?
    Hate to say it but that doesn't sound like a bad lifter at all sounds bottom end related. Looks like its struggling to stay running.
    04 Comp G.
  3. #3 Re: Help! Lifters or worse?
    Rod knock, its done.
  4. #4 Re: Help! Lifters or worse?
    how deep did you go into the engine? more info needed on what gaskets and why.
    it kinda sounds like a rockers not moving.
  5. #5 Re: Help! Lifters or worse?
    Pull the dipstick and I bet there will be sparkles in it.
  6. #6 Re: Help! Lifters or worse?
    This or drain the oil again
    04 Comp G.
  7. #7 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    It's def struggling to stay alive. But I had a LIM gasket go bad and noticed a bit of oil on the back of the motor so I figured I would change the head gaskets too. I just changed the oil about two days ago and still have the old oil in the catch, should I get check it?
  8. #8 Re: Help! Lifters or worse?
    Yea check the old oil for metal
    04 Comp G.
  9. #9 Re: Help! Lifters or worse?
    take the valve covers of and check your rockers are moving. like i said it sounds like a valve is not opening. easy check and if its that, its fixable.
    if you post another vid, rev the engine to 2,000 rpm's then drop the throttle, let go right to idle, that will tell a lot.
  10. #10 Re: Help! Lifters or worse?
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    correct me if im wrong but arent these motors just like the 3.1s where the push rods are different lengths? i know my uncle got a few mixed up on his car and it was makin some pretty bad noises
  11. #11 Re: Help! Lifters or worse?
    Nope pushrods are the same length
    04 Comp G.
  12. #12 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    No metal in the old oil or none on the dipstick
  13. #13 Re: Help! Lifters or worse?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I'd also vote Rod knock. Throw it up on CL and tell people the sound is cam lope. jk
    But if you don't plan on fixing it don't run it anymore. You'll have a lot more prospective buyer if it's still "driveable"
    I went NA when a whore left -$300 in my bank account.
  14. #14 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    Heres a second video of "trying" to run. I'm starting to also think I have a bad sensor somewhere because it just doesn't want to actually rev up at all. And I want to get it fixed but I have to figure out what is exactly wrong with it first.
    http://m.youtube.com/watch?feature=y...e_gdata_player
  15. #15 Re: Help! Lifters or worse?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    poor rod bearings it is starting to get the squeak
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  16. #16 Re: Help! Lifters or worse?
    yup it done blowd up.
    sorry time to start shopping for a engine.
  17. #17 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    Should I replace the rod bearing or then engine? And what could have caused this?
  18. #18 Re: Help! Lifters or worse?
    Apr 2009
    Elkhart
    Engine time could have been coolant or dirty got in the oil
  19. #19 Re: Help! Lifters or worse?
    find a used engine, they can be found for like 300 bucks most of the time for a rather new low miles n/a engine.
  20. #20 Re: Help! Lifters or worse?
    Jan 2012
    Indianapolis
    You can't just replace the bearings. You'd have to have the crank journals turned and the rod may also have to be machined if it's been distorted. By the time you tear it apart and rebuild it you could have gone to the junkyard and got a used motor for less. Just look for a car that has been crashed with lower miles. Preferably get one from a Buick as their drivers are normally older people and the gas pedal has never gone past 1/4 throttle. (No offense Scotty)
    My guess on why your engine is running messed up is that the rod knock is setting off the knock sensor and severely retarding the timing.
  1. Worse MPG?
    By secesh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2011, 08:43 PM
  2. Oil leaking in my car getting worse :/
    By Haulero in forum General Tech Discussion
    Last Post: 06-09-2011, 06:19 AM
  3. Starting getting worse
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-02-2011, 01:53 AM
  4. Window rattle worse
    By WhiteDevil in forum 04+ Specifics
    Last Post: 04-20-2009, 04:41 PM
