Thread: Help! Lifters or worse?
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    Thanks for all the the help guys. I guess it's a good thing that I have a 1999 Grand Prix Gt with an electrical issue sitting in my backyard. Do you think I could do the motor swap myself? I heard there was a thread somewhere on here about it.
  2. #22 Re: Help! Lifters or worse?
    Yea you can do it yourself.
    04 Comp G.
  3. #23 Re: Help! Lifters or worse?
  4. #24 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    Yup, just found that, should have used my eyes before asking but that's for motor and trans. Are there steps that I can skip so I don't have to pull the trans?
  5. #25 Re: Help! Lifters or worse?
    clearly you didnt read that. (just saw the pics) the pics there are to show you that bracket, and the backwards bell housing bolt. its hard to show that stuff when in the car.
  6. #26 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    Sorry Scotty, I saw his other one
    http://www.grandprixforums.net/showthread.php?t=69453
    I assumed you posted the same link. But you know what they say about assuming...
  7. #27 Re: Help! Lifters or worse?
    the link i posted is far less work. no need to pop the axles and such.
    theres a engine and tranny out the bottom how to around here as well. truth is that way looks to be the easiest way to go if you need both out.
  8. #28 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    I just replaced the trans less than a year ago so I think I'll keep it in the car. Although I wouldn't mind going HD
  9. #29 Re: Help! Lifters or worse?
    you could just drop a supercharged engine and tranny in the car. and its pcm. join the 2 belt club.
  10. #30 Re: Help! Lifters or worse?
    ^ that
    04 Comp G.
  11. #31 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    I have the second car and a full top swap in my minus a pulley and I believe a harness adapter. I actually have the tuned PCM for it too
  12. #32 Re: Help! Lifters or worse?
    on the road? or for parts? if its for parts you know what we all say lol
  13. #33 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    It's on the road, it tends to not want to start sometimes and will leave you stranded for random periods of time so I don't trust it or feel like trying to find a short in the harness so I don't drive it.
  14. #34 Re: Help! Lifters or worse?
    Quote Originally Posted by thewronggrandprix View Post
    sounds like a crank sensor gone bad.
    ok so your in the 2 belt club already.
    find that used n/a slow engine. mod its lim, and do the lim gaskets if need be and your done.
  15. #35 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    Do you mean port the LIM?
  16. #36 Re: Help! Lifters or worse?
    no, this thread. http://www.grandprixforums.net/showthread.php?t=46931 n/a engine also has these two ports. seal them and the upper intake can never get coolant in it again.
  17. #37 Re: Help! Lifters or worse?
    Jun 2013
    North Dakota
    That's pure genius
  18. #38 Re: Help! Lifters or worse?
    St. Louis
    Oh, and don't change the head gaskets on this one. They rarely if ever go on these cars. And if you do, get studs or new bolts as the old ones are not reuseable (TTY bolts).
  1. Worse MPG?
    By secesh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2011, 08:43 PM
  2. Oil leaking in my car getting worse :/
    By Haulero in forum General Tech Discussion
    Last Post: 06-09-2011, 06:19 AM
  3. Starting getting worse
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-02-2011, 01:53 AM
  4. Window rattle worse
    By WhiteDevil in forum 04+ Specifics
    Last Post: 04-20-2009, 04:41 PM
