Thread: 2006 GP 3.8 NA Stalls Hard Restart
Results 1 to 4 of 4
  1. #1 2006 GP 3.8 NA Stalls Hard Restart
    Jan 2014
    Nebraska
    Hi first time post, Thank you in advance for the help.
    I have a 2006 Grand Prix 3.8l after it warms up will intermittently out of the blue will stall. Everything in cab stays powered up. The car will not crank right after this happens until about 2-3 minutes later which it will crank over. At this point it will crank over for a while before it actually fires. when it does fire up it does so normally no sputtering.
    What has done so far: MAF sensor cleaned, Throttle Body Replaced.
    The information center has the following:
    Throttle Position Sensor Faulty - Throttle Angle Sensor
    Service Engine Light (MIL)
    Service Traction Light
    The car is unfortunately 3 hours away so cannot actually do any diagnostics at the moment.
    Any suggestions and advice is greatly appreciated.
    Thank You In advance again,
    Chris
  2. #2 Re: 2006 GP 3.8 NA Stalls Hard Restart
    Willoughby, Ohio
    the stalling sounds like a crank position sensor, other than that im not too DBW savvy
  3. #3 Re: 2006 GP 3.8 NA Stalls Hard Restart
    Jan 2014
    Nebraska
    I mainly work on diesels and few cars. From what I'm familiar with, even if the crankshaft and or camshaft sensor is out the vehicle should still crank?? Maybe there is some kind of reset time built into the control module logic possibly?? Not sure. I was hoping the no crank after it stalls for couple minutes would help point where the problem is since I don't think there is much stuff that will keep the vehicle from cranking correct??
    Not familiar with this exact car but this is based on knowledge from other vehicles I have worked on.
    Thanks For The Reply,
    Chris
  4. #4 Re: 2006 GP 3.8 NA Stalls Hard Restart
    oh if fails to turn the engine? then does so a few minutes later? check the grounds on the bell housing, theres 3 wires there, 1 fat neg bat cable, and two smaller. make sure the nut is tight, and the ends of the 2 small grounds wires are tight to the eye loop.
    if those are ok, check the pos cable on the starter.
    and of course clean your battery terminals make sure those are also tight.
  1. 2006 Equinox 3.4L V6 stalls
    By 4fanintexas in forum General Tech Discussion
    Last Post: 06-04-2013, 06:41 PM
  2. Owned 91 Grand prix 22 years ,hard start & stalls
    By traveltech in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 11:40 AM
  3. NEED HELP! 94 grand prix will only restart after waiting
    By cosmoe in forum General Tech Discussion
    Last Post: 07-15-2012, 07:22 PM
  4. 97 GTP runs (sometimes) Spits and sputters, then won't restart
    By RedIrocZ28 in forum General Tech Discussion
    Last Post: 04-12-2011, 09:16 AM
  5. 98 gtp engine stall restart dies
    By troubled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 05:57 PM
