Hi first time post, Thank you in advance for the help.
I have a 2006 Grand Prix 3.8l after it warms up will intermittently out of the blue will stall. Everything in cab stays powered up. The car will not crank right after this happens until about 2-3 minutes later which it will crank over. At this point it will crank over for a while before it actually fires. when it does fire up it does so normally no sputtering.
What has done so far: MAF sensor cleaned, Throttle Body Replaced.
The information center has the following:
Throttle Position Sensor Faulty - Throttle Angle Sensor
Service Engine Light (MIL)
Service Traction Light
The car is unfortunately 3 hours away so cannot actually do any diagnostics at the moment.
Any suggestions and advice is greatly appreciated.
Thank You In advance again,
Chris
