Quote Originally Posted by jalaltariq View Post
Okay, got the temp sensor swapped out. Changed the upper rad hose with new clamps. Get this though. Yesterday the fans ran continuously, today they don't run at all. I went to AZ and got everything I need except two fuses and two relays. I don't know what went wrong. I traced all the cabling/wiring and all the modules are connected properly. Car doesn't overheat but the fans won't come on which will lead it to overheat. I'm virtually convinced I need a new rad as its leaking in the corner and I don't trust my soldering hand. Any ideas what to check to figure the fans out?
Secondly, I rented a block tester and a coolant pressure tester. I ran the block tester. As the the car was at normal op temp, I pumped it seemingly forever. No change from blue, when the engine began to overheat, sucked in a bit of coolant and instantly turned yellowish green. So I changed fluid, and did it again. All the time I was pumping stayed blue, as soon as a bit of coolant expelled from the rad, green. So I don't know if I was doing it wrong or what. Today I'm going to run the coolant system pressure test as soon as my twins wake up. LOL Gotta love babysitting duty.
You're not supposed to get coolant in the block tester solution as it will instantly change color. I would guess that with the leak, you're sucking in air and you have a pocket stuck in there. Replace the rad and follow the bleed procedure and see where you end up.
