Thread: Aluminum Rocker Bolt Help - Next to injector
Results 1 to 9 of 9
  1. #1 Aluminum Rocker Bolt Help - Next to injector
    Sep 2012
    San Antonio
    Hello all!
    I should post more, but that's another topic.
    I have my '04 GP GT with 161K miles, and noticed my aluminum engine mount (attaches to the rocker) broke, so I went ahead and ordered the part to replace it so my engine doesn't dance around.
    Well I'm stuck now, and I need your help! I'm stuck on the last bolt (13mm, has a star bit on top), it attaches right next to an injector (don't worry, I'm uploading pictures!) and I need to see if I need to remove the injector, or the whole fuel rail itself. And if so, how do I do that?
    Let me know if you need any more pictures, I will happily supply them!
    Thank you in advance and I'll let you all know if I'm successful or not!
  2. #2 Re: Aluminum Rocker Bolt Help - Next to injector
    I thought the fuel rail had to come off for that bolt?
    I haven't worked on an N/A car in awhile.
    This is why I removed that crappy mount anyways once I took it off.
  3. #3 Re: Aluminum Rocker Bolt Help - Next to injector
    Sep 2012
    San Antonio
    You know I'm guessing it does. Mine was sheared off when I took the bracket off.
    Here's the two brackets, haha missing something?
  4. #4 Re: Aluminum Rocker Bolt Help - Next to injector
    get a l67 coil/ strut mount bracket, and never break it again.
  5. #5 Re: Aluminum Rocker Bolt Help - Next to injector
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    I took one off at the salvage yard saturday and didn't have to remove anything.
    Just use a 13mm open end wrench and take it out. It takes patience but it will come out. Just take the bolt and bracket out together.
    Sent from Not so smart smartphone
  6. #6 Re: Aluminum Rocker Bolt Help - Next to injector
    You can wiggle the bolt in with the fuel rail in there but it's easier to pull it off.
  7. #7 Re: Aluminum Rocker Bolt Help - Next to injector
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    As twisted said open end wrench and lots of patience because you can barley turn it.
    Sent from my HTC Thunderbolt using Tapatalk
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Aluminum Rocker Bolt Help - Next to injector
    Florida
    I agree with above just swap coil mount and replace that junk mount that always breaks
  9. #9 Re: Aluminum Rocker Bolt Help - Next to injector
    Part of the open end wrench club here.
  1. Rocker Arm Bolt size and grade
    By TEK310 in forum General Tech Discussion
    Last Post: 01-01-2014, 02:29 PM
  2. Rocker bolt help!!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 06-12-2012, 03:00 AM
  3. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  4. M90 is it aluminum?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 07-03-2010, 12:27 PM
