Thread: thermostat was FUBAR
Results 1 to 6 of 6
  1. #1 thermostat was FUBAR
    Dec 2013
    Millerstown Pa.
    Just picked up my GT this week and the temp gauge was only reading a little over 160 when completely warm.I decided to go ahead and change out the stat since its an easy job.I pulled the housing off and some azzclown had installed the stat incorrectly and put the wrong stat in!! I don't mean wrong temp I mean it was not the one for the car!! They put the stat in then put the rubber seal on TOP of it then tightened the whole mess down cant believe it wasn't leaking at least it was a 195 stat.I put the new one in and fired her up and the temp gauge now reads up where it should and the heater about melts ur flesh!!
  2. #2 Re: thermostat was FUBAR
    some people, its amazing aint it?
  3. #3 Re: thermostat was FUBAR
    Feb 2013
    37.295091, -121.930053
    thats good did the car temp also go up?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: thermostat was FUBAR
    Dec 2013
    Millerstown Pa.
    surpisingly the heater worked ok but the engine temp was really low all fixed now.Guessing I might as well do plugs and everything after finding that.
  5. #5 Re: thermostat was FUBAR
    Best of luck.. keep up informed on the funny stuff you find.
  6. #6 Re: thermostat was FUBAR
    Dec 2013
    Millerstown Pa.
    will do.Got the codes read PO410 so I gotta locate the air pump and check all the hoses and wiring and PO128 thermostat already done did new upper and lower today picked up new coolant temp sensor will install that tommorrow
  1. Thermostat
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-04-2012, 11:30 AM
  2. Thermostat Cap
    By Points70 in forum General Tech Discussion
    Last Post: 04-30-2012, 05:24 PM
  3. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
  4. DTC P0757 = Tranny Fubar'ed :(
    By GeddyLee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2009, 02:26 PM
  5. Fubar'ed my power locks. Any ideas???
    By Boatman in forum General Tech Discussion
    Last Post: 10-12-2008, 10:59 PM
