Thread: Helping a friend with 220K L36...
Results 1 to 7 of 7
  1. #1 Helping a friend with 220K L36...
    Feb 2013
    Missouri
    Hey everyone, a friend of mine's dad gave him a 2000 GT with about 220K on the clock. He said it needed LIM gaskets, but it hasn't even started since we got ahold of it. When we pulled it apart, everything looks VERY grimey, and the 2 and 4 intake runners (in the head) had antifreeze in them. We're trying to figure out if the engine is worth the money to get it running again. We pulled all 6 plugs, which were in the worst shape I have ever seen spark plugs, cranked the motor over a few times, and then ran a 2 compression checks....
    ................1st test 2nd test
    Cylinder 1: 120 PSI 120 PSI
    Cylinder 3: 150 PSI 160 PSI
    Cylinder 5: 110 PSI 110 PSI
    Cylinder 2: 100 PSI 100 PSI
    Cylinder 4: 195 PSI 150 PSI
    Cylinder 6: 165 PSI 130 PSI
    I've used this compression tester many times, so I trust it. I'm thinking this engine has reached the end of it's life...What do you guys think?
  2. #2 Re: Helping a friend with 220K L36...
    Feb 2013
    37.295091, -121.930053
    wow at cylinder 2. thats all i can say wow thats low compression. I do think it needs a rebuild on it or new motor
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Helping a friend with 220K L36...
    Yeaaaa I'm going to go ahead and say it's gone I wouldn't out any money into it instead spend that on a replacement.
    04 Comp G.
  4. #4 Re: Helping a friend with 220K L36...
    Feb 2013
    Missouri
    Just for clarification, the battery was a bit old, but the motor turned over fine, and didn't slow down at all after all the tests...so I don't think it would skew the results at all. Sounds like he's gonna be looking for a new motor. Problem is his dad said the trans was slipping as well...so new engine and new trans...before we say that though I'm gonna try and get some more info about the slippage from his dad. Maybe it's just a TCC solenoid or something.
  5. #5 Helping a friend with 220K L36...
    Yea because if your needing a trans too... Your gonna probably have to put more into it then the cars worth. Weightl out your options first.
    04 Comp G.
  6. #6 Re: Helping a friend with 220K L36...
    Feb 2013
    also have he thought about getting an sc motor?
  7. #7 Re: Helping a friend with 220K L36...
    Feb 2013
    Missouri
    Yep, that is the plan now...except for the 220K transmission...
  1. hi on here helping my dad
    By millertime in forum Introductions/Noob Questions
    Last Post: 07-31-2012, 01:32 PM
  2. 3100 high idle. nothing is helping.
    By mnracer550 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-21-2011, 09:38 PM
  3. Hi, helping friend with 97 3.8 GP
    By jackihyzer in forum Introductions/Noob Questions
    Last Post: 08-19-2010, 02:10 PM
  4. dynomat helping KR?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 02:17 AM
