Thread: Oil pan gasket
Results 1 to 20 of 25
  1. #1 Oil pan gasket
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    Has anyone done a oil pan gasket. I need to replace my. I have a engine cradle holder. I have most of all the tool and gasket. Does anyone have a full write up or a How-To. I have a 2004 3.8 N/A
  2. #2 Re: Oil pan gasket
    I live here. DirtDog's Avatar
    Jun 2012
    I have replaced mine on my old GP. Its definitely a pain job to do. Gotta remove motor mounts and raise engine a couple inches. How bad does urs leak
  3. #3 Re: Oil pan gasket
    04 Comp G.
  4. #4 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    About 2 quats every oil every change. Also my next job it the lim gasket too.
  5. #5 Re: Oil pan gasket
    Yea get that changed. 1 qrt every oil change seems to be normal according to GM but 2 sure isn't. At least you have a Cherry picker so it makes it a bit easier.
    04 Comp G.
  6. #6 Re: Oil pan gasket
    Dec 2012
    Where 4T65E's were born
    I don't see the job as too hard with a cherry picker. Just like changing motor mounts with one extra step. There is a video on youtube of a guy doing the job on a 3800, he makes it seem hard though.
    I found a newer one, real easy to me. http://www.youtube.com/watch?v=2f93YWC7aXc
    Sold.
  7. #7 Re: Oil pan gasket
    He has way more to worry about then the gasket. My god I couldn't even make it a minute into the video before stopping it. The cancer is horrible!
    04 Comp G.
  8. #8 Re: Oil pan gasket
    Jun 2012
    Bro I didn't think changing that gasket would be hard. It took me five hours and alot of cuss words. The bolts for the motor mounts are a *****
  9. #9 Re: Oil pan gasket
    Then it should take a normal person 1 hour
    04 Comp G.
  10. #10 Re: Oil pan gasket
    Jun 2012
    Exactly
  11. #11 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    This is what I'm using to pick up the motor. It was $50 at harbor freight.
    The video nice but the car is a 3.8 III with the aluminum sub-frame.
  12. #12 Re: Oil pan gasket
    It's the same procedure
    04 Comp G.
  13. #13 Re: Oil pan gasket
    Does that have the aluminum pan or the steel pan. If it's the aluminum pan, it's a super easy fix. If it's leaking, most likely it's the steel pan and the hardest part is that darn U bracket that is bolted on the motor. I personally ripped it off, had an aluminum pan and the new bracket waiting. It's worlds easier to swap and do.
  14. #14 Re: Oil pan gasket
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    my lim leaks about 1.5 to 2 quarts through the top between the v/c and intake every oil change also depends on the oil i use weirdly enough
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  15. #15 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    my car has the aluminum sub-frame and a steel oil pan.. how hard would it be to add the aluminum pan. anyone can post the part number and I take a look at the cost. I have the a new oil pan gasket for the steel pan. can it be reused or not.
  16. #16 Re: Oil pan gasket
    Jun 2011
    Texas
    GM came out with a TSB years ago on the oil pan leak on these engines. They say to put a 1/4 bead of RTV sealant on each side of the gasket. I use Permatex ultra grey. Considering how much of a pain this job is I always use RTV on the gasket.
  17. #17 Re: Oil pan gasket
    No offense but start using the search on the top of the page before making new threads. Just about everything you'll ever encounter is easily available and very common.
    http://www.grandprixforums.net/showthread.php?t=39797
    04 Comp G.
  18. #18 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    No Offense taking but I'm on my ipad and it suck to search with.
  19. #19 Re: Oil pan gasket
    Use tapatalk makes it very easy to be on the forums
    04 Comp G.
  20. #20 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    Ok download it. Thanks
  1. LIM gasket or Head Gasket?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:12 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  5. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
