Thread: Oil pan gasket
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Oil pan gasket
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    so this weekend I going to start the oil pan removal again. new aluminum pan, mounting bracket, bolts, oil sump pickup all on order. also going to drop the transmission pan and install a filter and new gasket. I have a lot to do. wish me luck
    I will take a lot of picture and update.
  2. #22 Re: Oil pan gasket
    Dec 2011
    Cortland
    How bad is it leaking? If its just seeping I'd drain the oil, clean the pan up and rtv it so you can save yourself a headache
  3. #23 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    Bad.
  4. #24 Re: Oil pan gasket
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by SLOGTP98 View Post
    2 quarts between oil changes
  5. #25 Re: Oil pan gasket
    Jun 2012
    Coral Spring, Fl
    Here lot of picture of my work. I do a write up soon.
    Part 1 tran mouth, tran pan.
    Jack up car and put on jack stand.
    I remove my front bumper cover. To make more room. To work.
    Take off front tires.
    Disconnect battery
    Remove coolant reservoir
    Remove Top motor mounts
    Connect support chain from alternator bracket to top motor mount bracket. I added a piece of heater hose to protect my new alternator
    Loop 2 support over motor mount bolt.
    Hook chain to fender engine support bar.
    Crank up support bar over side wing nuts.
    Pick up motor up by 4 to 6 inch. Pull out tran mount.
    Old on top new below.
    Next I remove all 20 tran bolts
    Watch after taking out the back10 bolt fluid will start to come out.
    "No picture"
    My tran pan. Just black particles.
    Clean everything with brake clean, remove tran filter.
    Also the remove black gasket on old filter. (Big pain in the ass)
    Install new gasket.
    "no picture"
    Install new tran filter
    Install new tran gasket, and pan.
    I start by putting every other both in. Then the other one.
    "No picture"
    Set to 80 in-pound,
    Then 120 in-pound.
  1. LIM gasket or Head Gasket?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:12 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  5. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
