Thread: Coolant Leak
Results 1 to 16 of 16
  1. #1 Coolant Leak
    SE Level Member blackthunder's Avatar
    Jun 2013
    London, Ontario
    So i had major leak at what seems to be a plug right below the exhaust manifold at the front of the engine. What plug is it? and is this common? its at the shop right now but they dont open till the morning. Just want to get a heads up on what it might entail.
    I poured water in the radiator and it poured out as fast as it was going in from just under the exhaust manifold.
  2. #2 Re: Coolant Leak
    Dec 2010
    DMV
    I believe that's the ect. The coolant temperature sensor.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Coolant Leak
    This motor is spun upside down, but on the front there are 2 frost plugs that are right below the exhaust manifolds.
    Do those look like the spot they are coming from???
  4. #4 Re: Coolant Leak
    Jun 2013
    London, Ontario
    yes, now when i had it up on the tow truck i took a look and saw alittle dribble out. didnt have any water with me anymore to be certain. but that looks exactly where it was comming from
  5. #5 Re: Coolant Leak
    Dec 2012
    Where 4T65E's were born
    Is that a second temp sensor?
    Sold.
  6. #6 Re: Coolant Leak
    Sep 2011
    Copperas Cove, TEXAS
    That's one of two Knock sensors next to the freeze plugs.
  7. #7 Re: Coolant Leak
    Jun 2013
    London, Ontario
    im hoping its just that, should I tell them to flush out the dex cool and put in the green stuff? I do believe i still have the original LIM Gasket and I have an 04
  8. #8 Re: Coolant Leak
    Sep 2011
    Yes, but your call.
  9. #9 Re: Coolant Leak
    Jun 2013
    London, Ontario
    so whats the downside of flushing out dexcool? i know the upsides, lol
  10. #10 Re: Coolant Leak
    Sep 2011
    None, just make sure all dex is out or you will get brown sludge.
  11. #11 Re: Coolant Leak
    Banned
    Oct 2013
    Moorhead, MN
    Dexcool allegedly lasts 100,000+ miles.
    If you can keep any trace of air out of your system for 100,000+ miles...
  12. #12 Re: Coolant Leak
    Cam.. you made me double take.
  13. #13 Re: Coolant Leak
    Jun 2013
    London, Ontario
    turns out it was my block heater that popped. should i be worried as to why it popped it out?
  14. #14 Re: Coolant Leak
    Sep 2011
    Things fail, the system is pressurized. In the last year I have blown two plastic coolant elbows, things happen.
  15. #15 Re: Coolant Leak
    Banned
    Oct 2013
    Moorhead, MN
    Tex, did you switch to aluminum, or not a fan?
  16. #16 Re: Coolant Leak
    Sep 2011
    Yes, I have aluminum elbow now, haven't had any problems.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. Coolant Leak
    By 99grandprixman in forum General Grand Prix Discussion
    Last Post: 01-06-2013, 06:43 PM
  3. Coolant leak NEED HELP!
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-03-2013, 10:05 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
