Thread: Top swap
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #1 Re: Top swap
    Jul 2012
    Chicago
    I assume L36 and L67 head gaskets are interchangeable?
    -Carl
  2. #2 Re: Top swap
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I got my gaskets individually from ZZP (minus the valve cover gaskets) I'd recommend do NOT use ZZP valve cover gaskets, get FelPro!!
    With that said, here is my ZZP shopping cart when I ordered gaskets:
    You won't need the thermostat unless you drop to a 180 and tune for it and you won't need the cam bolt. Also, subtract the valve cover gaskets and get FelPro. I learned the hard way, mine started leaking after about 2 weeks.
    Throttle body gasket is cheap. As for head bolts/studs, I spent the little extra and used studs. I am not into the torque to so much then turn an extra so many degrees BS. With the studs, 3-4 torque phases and done. I've used ARP studs on other builds including my 572 with the spray, never an issue... I'm pro stud, LOL they are an overkill but a lot easier.
    If I think of something else I'll post it. And matt is right. The head gaskets are a 9917PT and 9918PT which if you look at autozone.com they are L36 head gaskets... Who knows what's up with that, no telling but they work fine.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  3. #3 Re: Top swap
    Jul 2012
    Chicago
    Thanks for the answers and tips.
    -Carl
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
