Thread: Exhaust rusting out
Results 1 to 14 of 14
  1. #1 Exhaust rusting out
    Ohio
    I have an 05 GP that I had the single exit replaced with a dual exit exhaust almost 3 years ago. Now the welds at the Y have rusted out and it is getting louder and more annoying by the day. I was looking at a ZZP catback instead of just going to an exhaust shop around town but I wanted to get ride of the restrictive manifolds and DP too. Now I'm not sure what to do as if I go from one end to the other it's like $1000+ and I don't have that kind of cash right now. Anyone have any ideas or suggestions?
  2. #2 Re: Exhaust rusting out
    St. Louis
    Yea, find a local junkyard that has a GP in it with dual exits and snag the exhaust from it. Bolt it in and done. Way under 1K.
  3. #3 Re: Exhaust rusting out
    May 2012
    lebanon ohio
    I agree that is what I did got catback for 42 bucks at local upull junk yard.
  4. #4 Re: Exhaust rusting out
    Echo what the other guys are suggesting. Junkyard exhaust and add headers or a downpipe if you really want to do something. Should cost you 1/3 of $1000 if not cheaper.
    04 Comp G.
  5. #5 Re: Exhaust rusting out
    Ohio
    Called all around and none of them have any GPs with exhausts intact. Should I buy 2 mufflers tips and a welker pipe from autozone? Probably would be like $300ish. I thought about getting the cheaper ZZP but it's aluminized and in Ohio that would get eaten alive by the salt and brine in the winter
  6. #6 Re: Exhaust rusting out
    Aug 2011
    'Merica
    Check out the CL thread. I posted a catback I found in Ohio somewhere for cheap.
    Check it out.....http://cleveland.craigslist.org/pts/4054300084.html
  7. #7 Re: Exhaust rusting out
    Ohio
    Hmm a magnaflow setup.....it's a little bit of a hike but could be done. Ill have to check this out
  8. #8 Exhaust rusting out
    Stock lasted what 10 years...
    04 Comp G.
  9. #9 Re: Exhaust rusting out
    The exhaust on 04+ gps was aluminum?
  10. #10 Re: Exhaust rusting out
    Uhh I need to stop drinking and posting ignore that
    04 Comp G.
  11. #11 Re: Exhaust rusting out
    I was gonna say.
  12. #12 Re: Exhaust rusting out
    Ohio
    Hahaha well it made for some interesting comments. So back on exhausts what's everyone's opinion should I get the 304 stainless ZZP for $569 or the used magnaflow for $450?
  13. #13 Re: Exhaust rusting out
    Last time I checked ZZPs exhaust is loooooud! Might want to check out YouTube or something
    04 Comp G.
  14. #14 Re: Exhaust rusting out
    GTX Level Member blackflag's Avatar
    Virginia
    triple loud!
    check out borla, it sounds decent but the price is way higher than zzp.
    Otherwise pull your stock of by some pipes, buy a bender and welder (harbor freight) and have fun learning a new skill!
  1. Rusting Help
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 10-26-2011, 06:21 PM
  2. Rusting already?
    By Ninny in forum Visual/Body Modifications
    Last Post: 10-28-2009, 12:08 AM
  3. rusting?
    By Poil336 in forum Visual/Body Modifications
    Last Post: 08-29-2009, 07:11 PM
  4. rusting?
    By Poil336 in forum Shops and Community Heroes
    Last Post: 08-28-2009, 07:38 PM
  5. rusting
    By GMPUNK in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2009, 05:00 PM
