Thread: Trans pan drop question
Results 1 to 7 of 7
  1. #1 Trans pan drop question
    May 2012
    la mesa, ca.
    I dropped the Trans pan and changed the filter and gasket. It leaked so I got a fel pro OE style gasket. It still leaks.. Ugh. Is it new pan time? I torqued the pan Cris cross and gradual to 120 in lbs. from the center out. 04 GP N/A 135K mi. Anybody have the exact torque sequence? It's a 20 bolt pan.
    Thank you all very much!
  2. #2 Re: Trans pan drop question
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Re-use the original gasket if it looked good when you took it off. Other than that you've done the right things so far.....only thing to add would be to make sure that the mating surfaces where the gasket goes on both pan and trans itself is absolutely spotless.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: Trans pan drop question
    Grand Rapids, MI
    what he said ^^
    stock gasket is soooo much better. and is reusable
  4. #4 Re: Trans pan drop question
    Dec 2012
    Where 4T65E's were born
    Also make sure the pan isn't bent a bit if you let it hang by too few bolts when draining. I used an aftermarket gasket and torqued less than spec and it's dry as a bone. I also used a gasket scraper and got the surfaces very clean. The pan usually gets corrosion build-up on the mating surface.
    Sold.
  5. #5 Re: Trans pan drop question
    May 2012
    la mesa, ca.
    The pan being a little bent is the only thing I can think of. I got a new one and I'll try again this weekend. I'll let you know how it goes.
    Thanks again..
  6. #6 Re: Trans pan drop question
    May 2012
    la mesa, ca.
    Okay I put the new pan on and no leaks! I think my torque wrench was off and I over tightened it. The old pan was dimpled at the holes making it leak between bolts. Thanks guys!
  7. #7 Re: Trans pan drop question
    Dec 2012
    Glad you could fix it.
    Btw if you double post, you can click edit, then go advanced, and at the top left there's an option for deleting the post.
    Sold.
  1. pan drop < trans fails.
    By gtcoup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2012, 12:57 PM
  2. trans question??
    By slow99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2010, 11:18 PM
  3. 07 gxp trans question
    By goblue9976 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2010, 03:17 PM
  4. Trans question(s)
    By grmchne78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2010, 01:09 PM
  5. pulley drop question
    By blwn3800 in forum General Tech Discussion
    Last Post: 11-18-2009, 06:43 PM
