Thread: harmonic balancer issues
Results 1 to 11 of 11
  1. #1 harmonic balancer issues
    Feb 2013
    utah
    put on new balncer started just fine drove car about 2 miles tach started to jump around came to stop car died. it would restart but i had to keep my foot on the gas to keep it running with the brake on at the same time. any advice would be appreicated
  2. #2 Re: harmonic balancer issues
    What was the reason you put a new one on? Did you check out the CPS to make sure that that wasn't damaged.
    04 Comp G.
  3. #3 Re: harmonic balancer issues
    Bouncing tach signifies a bad crank pos. sensor...
    Probably needed that...not the balancer.
  4. #4 Re: harmonic balancer issues
    Quote Originally Posted by blueguy View Post
    This!
    Personally I would of spent the $30 and went ahead and replaced that while you were at it and save yourself the headache.
    04 Comp G.
  5. #5 Re: harmonic balancer issues
    Feb 2013
    utah
    the old one had a grove in it and was leaking oil car ran fine just a lot oil coming out so i replaced it could that cps gone out bcaused i power washed it off
  6. #6 Re: harmonic balancer issues
    Just don't drive the pulley on there wrong
  7. #7 Re: harmonic balancer issues
    Yay now you gotta go back and pull the HB back off and replace the CPS ~_~
    04 Comp G.
  8. #8 Re: harmonic balancer issues
    No..they just randomly go out it seems like. Water will not effect it unless for some strange reason you drenched it and it ruined it..chances are slim that that would happenZ
    04 Comp G.
  9. #9 Re: harmonic balancer issues
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I'd inspect the wiring/connector to crank sensor aswell while you at.
  10. #10 Re: harmonic balancer issues
    Quote Originally Posted by 231FUN View Post
    That too. Save yourself from having to go back in there again.
    04 Comp G.
  11. #11 Re: harmonic balancer issues
    Feb 2013
    utah
    i just order a new one it will be here tomorrow and your right i should have repalced it since i had it that far apart. on a good note i can now do it in about 15 min to get it apart thanks for all your input much appreciated
  1. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  2. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  3. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  4. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
