Do you are getting a coolant over temp warning, but the gauge is reading 210? The gauges on the dash aren't always the most accurate. It is possible you are overheating even though the gauge on the dash may not indicate it. If you have a good mechanic you trust, it would be a good idea to have them check it out. If they can duplicate the problem they can also check to see what the temp actually is.
