Thread: Ticking AFTERr 15 min of driving
Results 1 to 6 of 6
  1. #1 Ticking AFTERr 15 min of driving
    Aug 2013
    Lebanon, IN
    When I start my car, everythings fine..but as I drive it...the temp climbs up (210) and then BAM! a ticking noise....and then the Diagnostics shut it down for while. 0 power...then, the next day.the car starts and runs just fine again! Also worth noting...if you pull the oil dipstick..smoke comes out, VERY hot to the touch...so even though the gauge isnt showing hot...Maybe overheating??? Any 1st hand knowledge is appreciated! (im also due for an oil change..Idk if that effects the diagnostics at all)...*frustrated*
  2. #2 Re: Ticking AFTERr 15 min of driving
    Any info on the vehicle?
    Year, make, model, miles etc etc.
    Any DTC's???
  3. #3 Re: Ticking AFTERr 15 min of driving
    Aug 2013
    Lebanon, IN
    2004 Gt2 special edition. No turbocharger. 3800 motor. 203k. Idk what DTC is.
  4. #4 Re: Ticking AFTERr 15 min of driving
    DTC's is just another name for engine codes.
    So is the check engine light on?
    As for the smoke out the dipstick tube, you may have some coolant leaking into the crankcase and burning off or the PCV system is plugged.
  5. #5 Re: Ticking AFTERr 15 min of driving
    Aug 2013
    Lebanon, IN
    No check engine lights. Only one that says coolant over temp. See mechanic. I'm a girl sorry...what's a Pcv? And what needs to be done if that is the case?
  6. #6 Re: Ticking AFTERr 15 min of driving
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Do you are getting a coolant over temp warning, but the gauge is reading 210? The gauges on the dash aren't always the most accurate. It is possible you are overheating even though the gauge on the dash may not indicate it. If you have a good mechanic you trust, it would be a good idea to have them check it out. If they can duplicate the problem they can also check to see what the temp actually is.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  1. Need help ticking
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2012, 10:37 PM
  2. TB Ticking
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2012, 05:46 AM
  3. still ticking
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-15-2011, 07:25 AM
  4. ticking ?
    By gtcoup in forum General Tech Discussion
    Last Post: 02-20-2011, 07:41 PM
  5. Ticking
    By theboss98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:17 PM
