Thread: I need to change out my powersteering pump.
Results 1 to 7 of 7
  1. #1 I need to change out my powersteering pump.
    Edmonton
    Want to know if it is as hard as it looks to change the power steering pump. It seems like it is leaking from the bearing. I used Lukas power steering stop leak a couple of time but I think I am running out of luck. In the winter it is very loud. I have to top it up about every month, but in the winter I have to top it up once a week. Thanks.
  2. #2 Re: I need to change out my powersteering pump.
    check that the lines are not leaking first. or the rack.
    if its the pump, you'll want to take the front tire off, then take the lines off the pump from the wheel well. put a pan under it as its going to leak fluid out of the pump.
    then take the alt off, and the over flow tank if you have one there. now theres a hole in the p/s pulley, you use a 13 mm and a 3 inch extension through that hole. there are 2 bolts @ the 12 and 6 o clock areas.
    once the pump is off, you need a Gm p/s pulley puller, they cost a bout 30 bucks, or use the free rental deal at your local parts store. nothing else will take this pulley off with out damaging it.
    this puller also puts the pulley back on the new pump.
    with all this being said, its not that hard really, it may take a hour or so if your taking your time.
  3. #3 Re: I need to change out my powersteering pump.
    Edmonton
    Nice. Thanks for the advice. I think I can handle that.
  4. #4 Re: I need to change out my powersteering pump.
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    it's fairly simple. Also while you are in there you can completely remove the alternator bracket (if not 97) and replace your coolant elbows. It will give you plenty of clearance to get to the pump and the elbows are maintenance if you haven't changed them yet. Just a thought. If you have a 97, disregard what I just said.. LOL Also I found it easier to just use a deep well 13mm 3/8 drive without an extension and bending over the fender to get the bolts out... Either way, it's really an easy job. Just the lines are annoying to me.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: I need to change out my powersteering pump.
    if you got a 97 or 98 you can still pull that alt bracket and change the O ring on the cast elbow, and change the upper elbow, if you want, its not in the way whats so ever, nor is it any easier to with the pump off.
    changing the elbows at this time would be purely for piece of mind.
  6. #6 Re: I need to change out my powersteering pump.
    Edmonton
    Thanks Scottydoggs. This very informative and very encouraging. I'll go pick up the pump now that I know how to.
  7. #7 Re: I need to change out my powersteering pump.
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    My trans dipstick tube has been rubbing against my ps lines and it rubbed a whole in it so we welded the whole up but still has a tiny leak so I have to keep a check on it,the metal lines are the hardest ever to fix and I can't find replacements
  1. PowerSteering problem
    By DustinBjug in forum General Tech Discussion
    Last Post: 07-01-2013, 07:10 PM
  2. Power Steering pump took a poo. how to change?
    By 04GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2012, 10:24 PM
  3. Fuel Pump change
    By Myprixxx in forum General Tech Discussion
    Last Post: 07-03-2011, 06:38 PM
  4. I can't find my fuel pump resistor to change it...
    By RebelGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 07:48 PM
  5. problem with powersteering?
    By CMURDAx in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2010, 05:11 PM
