Thread: Cold Start Knock
Results 1 to 13 of 13
  1. #1 Re: Cold Start Knock
    St. Louis
    For the rear struts you could go with monroe. They should have a quik-strut setup where all you do it just remove the old, slap in the new and call it good. If they don't come with upper strut mounts then you will need those too.
    If those are too much $$$ then you can get just the strut and new upper mount and install yourself, as long as you have a way to compress the spring safely to remove it from the old assembly.
  2. #2 Re: Cold Start Knock
    Donating User PerusTC's Avatar
    Jun 2013
    Missouri/Kansas
    Thanks,I saw the Monroe's on sale at NAPA but I usually go to O'Reilly's.I like their warranties better.I will probably go with the whole shebang since the old ones are jello.
    Being old means your backside and your topside switch places.
  1. Knock at normal operating temps. But not when cold
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2013, 10:59 PM
  2. Cold start problems
    By jmn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2012, 10:43 PM
  3. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
  4. Cold Start Injectors
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 01:20 AM
  5. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
