Thread: Knock at normal operating temps. But not when cold
Results 1 to 2 of 2
OcalaGTP Knock at normal operating... 02-16-2013, 07:46 PM
Fivefingerdeathpunch Re: Knock at normal operating... 02-16-2013, 10:59 PM
  1. #1 Knock at normal operating temps. But not when cold
    SE Level Member OcalaGTP's Avatar
    Nov 2012
    Fl
    Recently had a oil pan denting issue on my 172k gtp. I have fixed the pan and replaced the pickup tube. Wasn't too bad but you could see where the pickup tube was marking the bottom of the oil pan.
    I thought i fixed it because when it could started i didn't have a knock. I test drove it. When the engine temp went up it started to have a knock to it. I don't drive it anymore. I have stated it a few times since to move it. It always sounds great when its cold. Doesn't start to knock until like 190 degrees.
    I was thinking maybe replace the rod bearings with the engine in car. Maybe the oil pump isn't doing well? The knock sounds pretty healthy when you hear it. Wouldn't it knock all the time if something was bad wrong? Instead of only when it warms up. Just looking for some idea's to get her back on the road one day.
  2. #2 Re: Knock at normal operating temps. But not when cold
    A video of the noise might help us.
    But if the rod bearing or main bearing spun you'd know it right away just about everytime, because half the bearing wouldnt be in the correct spot and the rods smacks the crank on every turn of the motor.
  1. 3800 Normal Operating Temp
    By 08 198 Champ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2012, 10:52 AM
  2. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  3. Coolant temps 2007 Grand Prix SC - Normal?
    By ViPER1313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2010, 02:06 AM
  4. What's normal operating temperature in traffic?
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2010, 09:23 AM
  5. FWI, T-stat and really cold temps
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-14-2009, 06:41 PM
