Thread: code 0442 Evap system 2001 3.8L
Results 1 to 4 of 4
  1. #1 code 0442 Evap system 2001 3.8L
    Nov 2009
    California
    My service engine light has gone on and off for the last year or so (sometimes I have to turn it off with the code reader) I replaced the purge valve that is toward the back of the engine several months ago. Seemed to fix problem, then light came on again about 3 weeks later. Same code every time (so many I've lost count now) Where are all the components located for this system? Is there any online source for diagrams or schematics? I want to replace everything I can as the car is due to be smogged this summer. The car runs fine, just having the light on constantly is annoying. Thanks
  2. #2 Re: code 0442 Evap system 2001 3.8L
    St. Louis
    DTC P0442: Evaporative Emission (EVAP) System Small Leak Detected
    This is typically the gas cap causing the issue. Try replacing it, clear the code and see if it comes back.
  3. #3 Re: code 0442 Evap system 2001 3.8L
    Chilliwack BC
    Quote Originally Posted by FordMan77 View Post
    especially if it's a walmart 10$ locking gas cap....before you replace it you can try cleaning the rubber seal on the gas cap with brake clean, as well as the filler opening it fits into. it's a free fix if it works...but small leak is typically gas cap
  4. #4 Re: code 0442 Evap system 2001 3.8L
    Apr 2013
    Hamilton
    If you can do a smoke test if it has a leak follow the smoke if it doesn't have a leak as fordman said its the gas cap
  1. 0442 code?
    By stewartj1998 in forum General Tech Discussion
    Last Post: 01-03-2015, 01:22 PM
  2. Need Help With Evap system engine code P1665
    By josh22 in forum Introductions/Noob Questions
    Last Post: 01-18-2013, 10:53 PM
  3. evap code
    By ryan head in forum Introductions/Noob Questions
    Last Post: 06-27-2012, 01:39 AM
  4. EVAP code help
    By craig1980 in forum General Tech Discussion
    Last Post: 06-07-2011, 05:21 PM
  5. Deleting EVAP System
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 01:48 PM
