Thread: Engine main bearing cap removal
Results 1 to 10 of 10
  1. #1 Engine main bearing cap removal
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    Hello. I got rid of the GTP a while ago and got a firebird. Long story short after many mods and a lot of fun, the engine is all kinda of messed up.
    I cannot find any information anywhere on my firebird forums so figured I'd ask here since it is the same engine different platform.
    How do I get the main bearing caps off to take the crankshaft out?
    And here is the culprit problem for doing so...
    ImageUploadedByTapatalk1364713695.288718.jpgImageUploadedByTapatalk1364713712.771447.jpg
  2. #2 Re: Engine main bearing cap removal
    look on the side of the block for side bolts into the caps. if no other bolts are found a tap to the side of the cap should pop it loose.
  3. #3 Re: Engine main bearing cap removal
    gardner,mass
    there are no more bolts you just need to wiggle it out, they sit in there tight
    also try taking like 2 short screwdrivers or something and sticking them in the bolt holes to get leverage to wiggle it back and forth till you can get something undernieth it
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: Engine main bearing cap removal
    gardner,mass
    another thing to note. do not mix those bearings up unless you plan on getting it machined and replaced. Just take the crank out use plastigauge to check if your clearances are ok and put it back together exactly how it came out. I honestly wouldnt be going that far into the engine unless you have a reason to
  5. #5 Re: Engine main bearing cap removal
    Surprise, AZ
    I most definitely have a reason to. Haha. ImageUploadedByTapatalk1364746841.029135.jpgImageUploadedByTapatalk1364746851.194587.jpg
    Gonna go take a look... Will keep updated.
  6. #6 Re: Engine main bearing cap removal
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Ouch. Best luck.
  7. #7 Re: Engine main bearing cap removal
    Surprise, AZ
    Eventually got the mains off. Everything is out of the engine except for the cam bearings in which we can't find a place that rents the tool.
    Does anyone have a recommendation of a shop that machines engines/heads?
  8. #8 Re: Engine main bearing cap removal
    Surprise, AZ
    Going to get a valve job on the heads and hot tanking the block hopefully this week or next.
  9. #9 Re: Engine main bearing cap removal
    the caps are tapered to be pulled in. they can be a pain to get out. GM specs a certain J tool for the process.
  10. #10 Re: Engine main bearing cap removal
    Surprise, AZ
    I took them out. Pair of vice grips and two people standing on the engine stand. Haha.
  1. Main or rod bearing problem!!
    By MidnightBlue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2012, 10:57 AM
  2. Main Bearing post mechanic work
    By GirlFriday in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2011, 10:03 AM
  3. Main engine bearing failure
    By 03grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 08:50 PM
  4. Main bearing caps
    By btamayo in forum General Tech Discussion
    Last Post: 09-19-2010, 03:01 PM
  5. Bad main bearing?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:05 AM
