Yup the pressure will be pushing on the outer nut but it won't turn cause its locked to the inner nut so the stud has to give and come loose
Alright thanks man so what ill do is put to nuts onto the bolt and tight them both as hard as possible onto the metal plate that the bolt is in then ill loosen up the inner nut and hopefully it will do what you said it will
