Thread: getting bolt with no head out of rear header join hole?
Results 1 to 12 of 12
  1. #1 getting bolt with no head out of rear header join hole?
    Aug 2012
    Nova Scotia
    any idea how to get it out? this what im talking about it were the corssover pipe bolts onto the rear headers. how can i get that bolt up through and out?
  2. #2 Re: getting bolt with no head out of rear header join hole?
    St. Louis
    You mean the stud? I would soak the daylights out of it with PB Blaster for a day or so, then grab it with a vice grip and see if you can back it out. Why do you need to remove the stud?
    I haven't looked closely at mine but sometimes the studs have a 6 point head on them at the very tip of the stud that you can stick a socket on and remove the stud. Which usually rounds off and you end up using a vice grip anyways, lol..
  3. #3 Re: getting bolt with no head out of rear header join hole?
    Aug 2012
    Nova Scotia
    Quote Originally Posted by FordMan77 View Post
    yep i mean the stud with no head on it.
  4. #4 Re: getting bolt with no head out of rear header join hole?
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    You can double nut it and tighten them together then loosen the stud with the inner nut
  5. #5 Re: getting bolt with no head out of rear header join hole?
    Aug 2012
    Nova Scotia
    Quote Originally Posted by Rob97gtp View Post
    so like put on nut on the other and tighten the top one and it will come up?
  6. #6 Re: getting bolt with no head out of rear header join hole?
    Jul 2012
    Kansas city
    Yea tighten the nuts together then loosen stud with inner nut not outer
  7. #7 Re: getting bolt with no head out of rear header join hole?
    Aug 2012
    Nova Scotia
    So put the two nuts on, then take a wrench or vice grips on the inner nut and loosen it and it will bring the stud out?
  8. #8 Re: getting bolt with no head out of rear header join hole?
    Jul 2012
    Kansas city
    Yup the pressure will be pushing on the outer nut but it won't turn cause its locked to the inner nut so the stud has to give and come loose
  9. #9 Re: getting bolt with no head out of rear header join hole?
    Aug 2012
    Nova Scotia
    Alright thanks man so what ill do is put to nuts onto the bolt and tight them both as hard as possible onto the metal plate that the bolt is in then ill loosen up the inner nut and hopefully it will do what you said it will
  10. #10 Re: getting bolt with no head out of rear header join hole?
    Jul 2012
    Kansas city
    No problem did it work for ya?
  11. #11 Re: getting bolt with no head out of rear header join hole?
    Aug 2012
    Nova Scotia
    Lol didn't try it yet
  12. #12 Re: getting bolt with no head out of rear header join hole?
    tennessee
    torch
  1. Hole In Header :-(
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2012, 10:36 AM
  2. Head bolt removal?
    By REDCRAPGP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2012, 05:10 PM
  3. head bolt help
    By Toms04compg in forum General Tech Discussion
    Last Post: 07-18-2012, 01:51 PM
  4. Balance shaft rear oil hole....
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2011, 04:49 PM
  5. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
