Thread: Vacuum wire???
Results 1 to 3 of 3
  1. #1 Vacuum wire???
    Jersey
    Long story short...i had my audio wire zip tied to the small wire that runs across the passenger strut tower. Of course with my luck it snapped when i needed to move something. Anyway ive heard people saying they replaced the hard plastic wire for a rubber wire but what size would i need and how would that be connected? Im thinking about just going to the dealer and let tham charge me an arm and leg but i'd rather get info on it first. Thank you
  2. #2 Re: Vacuum wire???
    Just put a rubber hose over the broken spot
  3. #3 Re: Vacuum wire???
    Take your broken section off from the motor to the break and drive to the parts store, this should not cause you a problem with the motor. Walk into the parts store and ask where the bulk vacuum line/rubber hose is located.
    Use the broken end of the hard line you have to find a suitable size to slip over it firmly. I like to have about an inch of hose over the hard line for a repair. Buy a full foot of the size that works for you. Smile that it's likely under $2.
    Drive home, cut the hose to a reasonable size to fix the broken area and reattach the lines etc. Put your leftover piece in a safe place for the next repair.
  1. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. Help with vacuum T's
    By Nickell in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 07:07 PM
  4. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  5. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
